Convert any images to HEIC on Windows7
Xn User
Post by Xn User »
Hi )
I have two question.
1) as convert to HEIC in XnConvert ?
2) why HEIC available only x64 version ?
When I try convert from JPEG2000 to HEIC in Windows 7 x64 and use XnConvert x64 , I can not recive compressed file. Process compression run , but result file not make. Why so ?
Also , I can not save as HEIC in XnView MP for Windows x64 systems. All result same.
Thank you )
Re: Convert any images to HEIC on Windows7
Current version of XnView MP use Microsoft plugin by default, XnView MP 0.97.0 has a new plugin to load/save HEIC files
Xn User
Post by Xn User »
But 0.97 not saved in HEIC
Xn User wrote: Wed Oct 07, 2020 11:13 pm But 0.97 not saved in HEIC
you can save in HEIC with 0.97
Xn User
Post by Xn User »
xnview wrote: Thu Oct 08, 2020 12:05 pm
I can not save in HEIC with 0.97. File easy not saving.
Xn User
Post by Xn User »
In 0.97 include this plugin
Xn User
Post by Xn User »
And yet question , HEIC there is lossless compressor or only lossy mode ?
Tapio
Post by Tapio »
xnview wrote: Tue Oct 06, 2020 9:59 amCurrent version of XnView MP use Microsoft plugin by default, XnView MP 0.97.0 has a new plugin to load/save HEIC files
Will you put the new plugin into XNConvert as well? Would be very welcome. I need to load HEIC and save to jpeg. There's some threads around here, but I didn't manage to make XNConvert reading heic.
Xn User
Post by Xn User »
Tapio wrote: Mon Oct 12, 2020 11:00 am
XnConvert x64 can read HEIC , but me need not R/O , me need R/W and only if HEIC lossless format and always will be to smaller what JPEG2000 LuraWave.
Tapio
Post by Tapio »
Xn User wrote: Mon Oct 12, 2020 9:00 pmXnConvert x64 can read HEIC , but me need not R/O , me need R/W and only if HEIC lossless format and always will be to smaller what JPEG2000 LuraWave.
XNConvert can maybe read some specific HEIC files. Or maybe after adding some plugin dlls to mysterious places (nothing worked for me), or maybe after buying some software from the MS Store, idk. It cannot read my files. Says "No image file".
S:\Bilder\2020-10-11 iPhone\2020-05-03_029.HEIC 0x0x0 : Keine Bilddatei
Xn User
Post by Xn User »
XnViewer MP can read your files ? If yes , easy replace plugins folder in XnConvert and overwrite all files which such in XnView MP in XnConvert.
Tapio
Post by Tapio »
Xn User wrote: Tue Oct 13, 2020 3:55 pmeasy replace plugins folder in XnConvert and overwrite all files which such in XnView MP in XnConvert.
Then it says that the application cannot start because no QT platform could be initialized. Took the plugins folder of XNViewMP.
Yes, XNViewMP can read my files.
Xn User
Post by Xn User »
Tapio wrote: Thu Oct 15, 2020 11:26 am Then it says that the application cannot start because no QT platform could be initialized. Took the plugins folder of XNViewMP.
Allright , I knowned what this help you.
Tapio
Post by Tapio »
Xn User wrote: Thu Oct 15, 2020 1:05 pm
? No, only XNViewMP can read my HEIC. XnConvert can't, no matter what I do. But I think I read somewhere Pierre will add HEIC support to XnConvert in the next version.
