Could not open folder with polish letters
natash
Post by natash »
Hi All,
I am not able to open folders and pictures from folder which has got in name some Polish letters i.e.
Zdjęcia
Nieruchomości
If folder contains any Polish letter I am not able to open it via XnView and also not able to open any picture from this folder even using Internet Explorer.
I have: "Error opening the file. C:\xxxx\yyyy\zzzz.jpg"
Re: Could not open folder with polish letters
XnView Classic does not fully support Unicode, your only solution is probably to use XnView MP, the newer software under active development...
