Hello all,
I'm looking for some help here. I want to use XNview to add categories to my images. I think I don't really understand category sets and I wonder if there are any resources that explain them? When I have the pane open I can hit the little plus button to create a new set for example Landscapes. If I then hit manager I can add sets. So far so good. So I go to landscapes from the drop-down and I see the sets and I have added (for example rural, urban and so forth) and belief all of those headings I see categories such as rural exploration, trees, grass, sunshine et cetera et cetera. I then add a second category set which I call People. I then do the same with that category, adding sets and categories to those sets. But once I've done that if I switch between different categories sets via the drop-down at the top of the pane I do not find that the sets in each pain a different. So I go to people and I still see rural landscapes and so forth below. Please see screenshot attached. What I would have expected would be to be able to select a picture of a person and select people from the drop-down in category sets and have only the sets of categories show up that are related people. Am I misunderstanding? I wish there was some rather better documentation on this program that would help me with this.
Thanks very much for any help that anyone can offer.
Phil
Category sets
Category sets
- Attachments
- ScreenHunter 179.jpg (19.38 KiB) Viewed 1356 times
- ScreenHunter 178.jpg (20.54 KiB) Viewed 1356 times
Re: Category sets
"Categories" is a tool that allows fast tagging, filtering, and writing iptc or xmp keywords.
But if you have a lot of categories, it's painful to scroll, or expand subcategories when tagging.
"Categories sets" in XnViewMp is a way to show only some categories if you have hundreds, it saves time.
Example, you are tagging people in your family, you can create a set "family" to show only these persons.
One click on a button for each person, it's done.
You don't need to create a parent category if you don't want to use the keyword "family".
With some other softwares, you must create a parent keyword ("family"), and set it as a "non writable keyword"
Catalogage avec XnviewMP :
Re: Category sets
Thanks for this but I'm seeing it as only enabling me to order the sets and have some open and some closed (expanded, I guess) but not able to actually hide sets so if I have my People categor set open the still life set still shows up but down the bottom. It's not a big deal and I guess could be useful?
