search dialog (ctrl-f) and ENTER
Locked
loth
Post by loth »
origin: http://newsgroup.xnview.com/viewtopic.php?p=19488#19488
if i type in the name in the searchdialog and press enter, xnview searches the files and shows the result.
if i don't like the result and try to specify the search (i.e. by changing the filename) and press enter again.
the result is directly shown. i don't have to click on view. this is irritating.
loth
Dreamer
Post by Dreamer »
I can confirm this. It's a bit annoying.
However, when Enter is pressed (to search), next time Enter is pressed it should show the results, if this is not possible, don't fix/change it rather...
Thanks loth, I'm not sure if this is a 100% bug, but I think it's better place here.
Dreamer wrote:I can confirm this. It's a bit annoying.
Yes annoying, try to find a solution...
Locked
