Please, don't post bugs or request in this topic!
You can download XnView MP 0.96 here:
Windows x32 ZIP version SHA256: 6ED6F6F80BCACEC396FB19FE4D652D2508B735DFE42FA4A121B9ED360FAEBA3B
Windows x32 SETUP version SHA256: 9261CED34C82BC1BFC1D310B5A33A2A0F1DED749C21080E23AC7E51921BC9C6C
Windows x64 ZIP version SHA256: 7C5DB6DD19EFE3A6511B97F3C882AC8D534E383E48333ED11F042BA4D8DAB211
Windows x64 SETUP version SHA256: CA999FFEA707FABE4D30BC558CC87C2864CF1C018AFC3CF1018FFF7FBA55FC74
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 DMG version SHA256: 84E18BAB33DD7DE97FA16340EA5E95424FF7E2C78E912DA229CC64DE0518C007
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version SHA256: B5BEBD94EEFA0E5314CB08D83222E6561A08B67B78D430C962F9D5FED8CEB5DB
Linux x64 DEB version SHA256: 973EBC61AE8BE278DE7CAE66E505D46C7079A8BDB016CE5203330BD58FEE5A27
ARM version: http://download.xnview.com/XnViewMP-linux-arm.tgz http://download.xnview.com/XnViewMP-lin ... _armhf.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP.gl ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 0.96:
1752: [New] AVIF support - viewtopic.php?t=38649
1750: [New] Experimental 'Fit window to image' - viewtopic.php?=40137
1747: [New] Search: category contains/does not contain/is
1746: [New] Search: in pathname - viewtopic.php?t=38591
1739: [New] Capture: Hide Xn - viewtopic.php?t=39511
1735: [New] Compare: shortcuts - viewtopic.php?t=39844
1733: [New] Paste keep ratio - viewtopic.php?t=39779
1727: [New] Show info always visible - viewtopic.php?t=39490
1726: [New] Batch convert: 'Close after conversion' - viewtopic.php?t=39403
1724: [New] Paste special - viewtopic.php?t=39572
1721: [New] Paint: Background color for Text - viewtopic.php?t=39889
1720: [New] 'New image' in image mode - viewtopic.php?t=39942
1719: [New] Copy/Paste GPS data - viewtopic.php?t=36962
1718: [New] Width/Height in mm placeholder - viewtopic.php?t=39847
1717: [New] Batch Convert: Numeric numerator + output filename available in "Text" - viewtopic.php?t=39996
1714: [New] Batch convert: White balance
1754: [Bug] Move file & excluded folder - viewtopic.php?t=38426
1753: [Bug] Save a screenshot, statusbar not updated
1751: [Bug] MacOS: Translation of standard buttons
1749: [Bug] Rename & companion file - viewtopic.php?t=39613
1748: [Bug] Not possible to overwrite embedded thumbnail on some JPEG
1745: [Bug] Rename field not visible in thumbnail view mode - viewtopic.php?t=39514
1744: [Bug] Maximum view tab not work - viewtopic.php?t=39536
1743: [Bug] Auto Correct doesn't work correct-ly - viewtopic.php?t=39709
1742: [Bug] Search Similar: can't close dialog - viewtopic.php?t=39314
1741: [Bug] Import: aae not copied - viewtopic.php?t=38795
1740: [Bug] {File type} place holder - viewtopic.php?t=39272
1738: [Bug] Transfer: Multiple lines - viewtopic.php?t=39875
1737: [Bug] Batch rename: spacing between columns - viewtopic.php?t=39874
1736: [Bug] Open second image & fullscreen - viewtopic.php?t=39676
1734: [Bug] "Properties" column shows incorrect # of colors - viewtopic.php?t=39894
1732: [Bug] Compare: close view - viewtopic.php?t=39819
1731: [Bug] Compare: Cannot turn off "Confirm file delete" - viewtopic.php?t=39870
1730: [Bug] Windows taskbar text - viewtopic.php?t=39826
1729: [Bug] Placeholder & Current date - viewtopic.php?t=39790
1728: [Bug] Tooltips on category - viewtopic.php?t=39667
1725: [Bug] GPS in detail view - viewtopic.php?t=39686
1723: [Bug] File Listing: Append to file - viewtopic.php?t=39797
1722: [Bug] Unknown file info not shown in toolbar - viewtopic.php?t=40091
1716: [Bug] Image viewer slow with big folder - viewtopic.php?t=40012
1715: [Bug] Slideshow: window doesn't close
1713: [Bug] Customized format text color not used in 'details'
1712: [Bug] Cut and paste files on selected folder can delete original files - viewtopic.php?t=40053
1711: [Bug] Film simulation crash
1710: [Bug] Windows: if drive letter is lower case in pathname, duplicate entry in catalog
1709: [Bug] MacOSX: Folder without subfolder can have arrow to expand
1708: [Bug] Sharpen setting not used for folder's thumbnail - viewtopic.php?t=39916
1707: [Bug] Multiple spaces in Info view - viewtopic.php?t=39881
Changelog 0.95:
1706: [New] Qt 5.12.6
Changelog 0.94.3:
1705: [New] Batch convert - 'Transparent color'
1704: [Bug] Font size in Fusion theme - viewtopic.php?t=39872
1703: [Bug] EXIF user comment - viewtopic.php?t=39873
Changelog 0.94.2:
1700: [New] 'Remove alpha' - viewtopic.php?t=39592
1694: [New] Video date - viewtopic.php?t=39739
1702: [Bug] GS 9.50 un*x - viewtopic.php?t=39753
1701: [Bug] zoom field keep focus - viewtopic.php?&t=39627
1699: [Bug] Thumbnails not loaded at startup - viewtopic.php?t=39754
1698: [Bug] Companion files deleted in edit mode, setting not used - viewtopic.php?t=39587
1697: [Bug] Categories not updated if file (IPTC) modified outside - viewtopic.php?t=39546
1696: [Bug] New files, no metadata - viewtopic.php?t=39690
1695: [Bug] Zoom field steals focus - viewtopic.php?t=39692
1693: [Bug] Compare similar content very slow - viewtopic.php?t=39695
1692: [Bug] Linux: Not all datas from ExifTools - viewtopic.php?t=39701
Changelog 0.94.1:
1691: [Bug] Problem with Ghostscript 9.50
1690: [Bug] Use file date if no exif date setting (useFileDateWhenNoExif in xnview.ini)
1689: [Bug] Browse categories result in fullscreen not possible - viewtopic.php?t=39638
1688: [Bug] Non image files not shown in browser
1687: [Bug] 'Edit IPTC' doesn't write fields - viewtopic.php?t=39620
Changelog 0.94:
1679: [New] Sort by EXIF date modified - viewtopic.php?t=39345
1676: [New] SQLite 3.29.0
1670: [New] Offset tool - viewtopic.php?t=37552
1669: [New] Unsharp Mask
1619: [New] Webp: Presets
1613: [New] Use Windows HEIC WIC decoder/encoder - viewtopic.php?t=39108
1612: [New] JPEG-XR export does not work - viewtopic.php?t=38401
1611: [New] Batch convert: Reorder items - viewtopic.php?t=38798
1606: [New] Automatic crop: edges selection - viewtopic.php?t=38015
1600: [New] DDS Bcn compression
1599: [New] Libjpeg 2.0.3
1596: [New] Template - part of text
1595: [New] Transfer: Copy data to Metadata
1593: [New] 'Go to x,y location'
1581: [New] XIM format - read support
1570: [New] RAW color matrix setting
1598: [New] Similar: 'only folder' setting
1657: [New] Canvas resize: position matrix - viewtopic.php?t=38776
1656: [New] Print selection - viewtopic.php?t=38753
1655: [New] Setting to start with always same size - viewtopic.php?t=38723
1654: [New] Filter: 'Apply' to validate current filter - viewtopic.php?t=38724
1653: [New] Edit IPTC: double click to add History item - viewtopic.php?t=38709
1649: [New] Edit IPTC: open lastest tab setting - viewtopic.php?t=38694
1648: [New] Folder always sorted alphabetically setting - viewtopic.php?t=35126
1646: [New] Edit IPTC: in view mode, write added - viewtopic.php?t=38713
1644: [New] Desaturate - viewtopic.php?t=38381
1642: [New] Curves: Buttons instead combobox - viewtopic.php?t=38489
1639: [New] Contact Sheet: Background image - viewtopic.php?t=38550
1638: [New] Custom params for toolbar's command - viewtopic.php?t=38396
1636: [New] Quick search in description - viewtopic.php?t=38495
1634: [New] Slideshow: in .sld, you can add folder (must ends with '\' or '/') - viewtopic.php?t=38502
1633: [New] Load slideshow .sld from XnView Classic - viewtopic.php?t=38502
1629: [New] Create new image - viewtopic.php?t=38577
1686: [Bug] Batch Convert: Output path - viewtopic.php?t=39503
1685: [Bug] webP & metadata settings - viewtopic.php?t=39479
1684: [Bug] Categories added on TIFF - viewtopic.php?t=39375
1683: [Bug] PAM CMYK1682: [Bug] Replace color - viewtopic.php?t=39012
1681: [Bug] Batch Convert: ICC not kept for PNG - viewtopic.php?t=39376
1680: [Bug] Non image files displayed before filtering - viewtopic.php?t=39358
1678: [Bug] BMP - viewtopic.php?t=39313
1677: [Bug] Catalog - rebuild thumbnails dead lock - viewtopic.php?t=39275
1675: [Bug] PSD fix alpha channel setting - viewtopic.php?t=39254
1674: [Bug] "return to browser" in fullscreen - viewtopic.php?t=39015
1673: [Bug] Resize IPTC dialog - viewtopic.php?t=39247
1672: [Bug] Companion files not copied/moved with Copy/Move to - viewtopic.php?t=39164
1671: [Bug] Category search pane - viewtopic.php?t=37779
1668: [Bug] Browser: EXIF rotation (field) doesn't update timestamp - viewtopic.php?t=38866
1667: [Bug] Change color depth & background color - viewtopic.php?t=37996
1666: [Bug] Catalog relocate - viewtopic.php?t=37644
1665: [Bug] 'Match all' + rating + categories - viewtopic.php?t=38115
1664: [Bug] Random quick slideshow shows at most ~32,000 images - viewtopic.php?t=38721
1663: [Bug] Wrong focus after returning from fullscreen - viewtopic.php?t=37727
1662: [Bug] Edit mode: File size displayed after rename - viewtopic.php?t=38432
1661: [Bug] Fusion dark theme & detail view - viewtopic.php?t=38022
1660: [Bug] Fusion dark theme - viewtopic.php?t=39122
1659: [Bug] Batch convert: Use CPU Core's - limited to last used setting - viewtopic.php?t=38669
1658: [Bug] Maximized to Fullscreen - viewtopic.php?t=38700
1652: [Bug] Edit IPTC: 'Write' & 'don't load fields' - viewtopic.php?t=38237
1651: [Bug] Search: mixing base path and parent folder - viewtopic.php?t=31366
1650: [Bug] Not possible to change shortcut for capture/import clipboard/scan - viewtopic.php?t=38673
1647: [Bug] Switching printers lets XNView MP ignore margin settings - viewtopic.php?t=38509
1645: [Bug] Batch rename: Not possible to use arrow to select item - viewtopic.php?t=37022
1643: [Bug] File listing: Invalid field name with date - viewtopic.php?t=38483
1641: [Bug] Compare: Thumbnails not always refreshed at startup - viewtopic.php?t=37955
1640: [Bug] System context menu on folder tree & DPI - viewtopic.php?t=38470
1637: [Bug] Background color of Category Sets & Actions with Dark Fusion theme - viewtopic.php?t=38594
1635: [Bug] 'Show all files (recursive)" in menu - viewtopic.php?t=38610
1632: [Bug] Batch conversion uses disabled checkbox setting - viewtopic.php?t=39209
1631: [Bug] Rename folder not possible if browsed before
1630: [Bug] Resize image/canvas presets ignore 'keep ratio' setting - viewtopic.php?t=38581
1628: [Bug] Windows: Unable to paste on root drive - viewtopic.php?t=38264
1627: [Bug] MacOSX: Multiple instance not possible - viewtopic.php?t=39177
1626: [Bug] Problem when renaming/moving files with unicode in catalog - viewtopic.php?t=36410
1625: [Bug] WebP: target file size not used - viewtopic.php?t=39155
1624: [Bug] Capture: XnView window must not be restored after a capture (multiple capture)
1623: [Bug] PSD: IPTC no correctly written
1622: [Bug] Batch Convert: Resize - Longest/shortest & percent
1621: [Bug] TIFF - viewtopic.php?t=38180
1620: [Bug] Custom labels & validation - viewtopic.php?t=39128
1618: [Bug] Replace dialog: filesize is missing - viewtopic.php?t=39138
1617: [Bug] PSD: Error when writing metadata - viewtopic.php?t=39137
1616: [Bug] Can't save 1bit into webp - viewtopic.php?t=39104
1615: [New] Compare: Tabs - viewtopic.php?t=38746
1614: [Bug] Canvas Resize: Background color not saved
1610: [Bug] Compare: color labels - viewtopic.php?t=38744
1609: [Bug] Missing time total/elapsed for video playing
1608: [Bug] Video thumbnail creation locks - viewtopic.php?t=38045
1607: [Bug] Clipboard at exit - viewtopic.php?t=25527
1604: [Bug] Search: not using sidecar - viewtopic.php?t=38967
1603: [Bug] Registry not correctly detected - viewtopic.php?t=39014
1602: [Bug] Slow GIF playback - viewtopic.php?t=39005
1601: [Bug] {MPixel} format - viewtopic.php?t=39016
1597: [Bug] Import&Sort: EXIF date always used in filename template
1594: [Bug] Crash {META:LensID}
1592: [Bug] Batch convert + "Use CPU Cores" very slow to start with 30,000 images - viewtopic.php?t=38943
1591: [Bug] Height ignored when resize 'fill' & keep ratio off - viewtopic.php?t=38921
1590: [Bug] Canvas resize - Relative - 'mm' doesn't work - viewtopic.php?t=38924
1589: [Bug] Crash in curve - viewtopic.php?t=38903
1588: [Bug] CVE-2019-12151
1587: [Bug] Remote files must not be added to recent files
1586: [Bug] Filter with rating AND color label doesnt work - viewtopic.php?t=38890
1585: [Bug] Categories partly updated after 'Edit IPTC' - viewtopic.php?t=38878
1584: [New] Batch convert: Hot folders without auto processing - viewtopic.php?t=38825
1583: [Bug] Batch convert: Preview not updated - viewtopic.php?t=38856
1582: [Bug] Thumbnail for FLV not created - viewtopic.php?t=38867
1580: [Bug] Paste clipboard problems - viewtopic.php?t=38846
1579: [Bug] SPACE can't be assigned - viewtopic.php?t=38755
1578: [Bug] Folder thumbnail not created in the right order - viewtopic.php?t=38763
1577: [Bug] If thumbnail for video is disabled, slow when checking files
1576: [Bug] Crash on rotate 180 on binary image (w=1305)
1575: [Bug] 8bits+transparency => 32bits problem
1574: [Bug] Rename overwrite file if exist (usb key)
1573: [Bug] Dead lock on ppt
1572: [Bug] No icon for .url - viewtopic.php?t=38743
1571: [Bug] iThmb format
1569: [Bug] Jxr Half - viewtopic.php?t=38679
1568: [Bug] Import categories from Windows Live Fotogallery - viewtopic.php?t=38612
Changelog 0.93.1:
1567: [Bug] Print only first page - viewtopic.php?t=38651
1566: [Bug] HEIC on Mac
1565: [Bug] Stars on preview don't change rating
1564: [Bug] Error reading TGA 16bits RLE
1563: [Bug] Exit Artist shown on NEF file
1562: [Bug] Prev/Next not working with two or more opened tabs - viewtopic.php?t=38523
1561: [Bug] Problem to move video files - viewtopic.php?t=38488
1560: [Bug] Fullscreen view mode - Focus on image lost after edit - viewtopic.php?t=38490
1559: [Bug] Contact Sheet: Folder not restored - viewtopic.php?t=38570
1558]: [Bug] SPACE key settings - viewtopic.php?t=38478
1557: [Bug] WebP 32bits & metadata - viewtopic.php?t=38514
1556: [Bug] XCF (floating pixel) crash
1531: [Bug] Linux move to trash - viewtopic.php?t=37989
1555: [Bug] Windows Save dialog, Most used formats no more at top
XnView MP 0.96
XnView MP 0.96
Re: XnView MP 0.96
I want to thank you, too! The new AVIF file format is fantastic and a great advantage and also the fixed bugs.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill
OS: Windows 10 Pro x64 (latest updates) | XN-View (latest stable version) |XnViewMP (latest stable version) | XnConvert (latest) | Adobe Photoshop Elements 2022 & Elements XXL 9
