GPS data duplicate photo
DMHas
Post by DMHas »
Hello all,
when I add GPS datas with XnViewMP (0.95) the programm create a new photo with the GPS data. At this moment is all fine. But the new file with GPS datas have a smaller size then the original. (For my opinion the file size should be greater :?: )
May be it is possible to add an option "don't duplicate file befor add GPS datas" or something like this? (So that no copies of a file will be created.)
Greetings DMHas
Re: GPS data duplicate photo
DMHas wrote: Sun Mar 15, 2020 9:22 am when I add GPS datas with XnViewMP (0.95) the programm create a new photo with the GPS data. At this moment is all fine. But the new file with GPS datas have a smaller size then the original. (For my opinion the file size should be greater :?: )
Not always even if compressed image data are not modified
Settings>File operations
DMHas
Post by DMHas »
Many Thanks for your reply Pierre!
