Deleting second to last file
TheEvilHammer
Post by TheEvilHammer »
If you delete the second to last file of a folder in View mode (and you have the option enabled to automatically move to the next file upon file delete), XnView moves to the next (last) file, but the "File >" button is not disabled. Clicking on the "File >" doesn't result in any unexpected behavior, but it shouldn't be enabled.
Re: Deleting second to last file
TheEvilHammer wrote:If you delete the second to last file of a folder in View mode (and you have the option enabled to automatically move to the next file upon file delete), XnView moves to the next (last) file, but the "File >" button is not disabled. Clicking on the "File >" doesn't result in any unexpected behavior, but it shouldn't be enabled.
Right i'll fix it
