Add a build number to the alpha version
Locked
Post by Guest »
Is more simple for the people identify the last version of software if you add a build version.
1.82 Alpha 001
In this case the last in the server is 1.82 Alpha 002
For people that like to try software is more reconizble..
Keep the good work.. ;)
XnView 1.82 alpha
Re: [Sugestion] Add a build number to the alpha version
Anonymous wrote:Is more simple for the people identify the last version of software if you add a build version.
1.82 Alpha 001
I think that i'll put only one alpha in the forum. After we 'll have a beta
1.82 Alpha 001
I support this. One digit should be enough (e.g., Alpha 1).
Freeware-User
Post by Freeware-User »
xnview wrote: I think that i'll put only one alpha in the forum. After we 'll have a beta
This is for a better numbering the build.. Because you have put in download, 2 diferent versions in 2 days.. The nunbers is for highlight the diference..
If you want, you can add a version every day or weekly, and that number make them unique.. ;)
Is only a sugestion.. More build for public, best report of bugs in diferents OS and hardware..
Regards..
Free, even in software. # (Sorry for my english..) :( # PC Spec: P4, 512mb ram, Onboard VGA, WinXP Pro SP2 PTG
Freeware-User
I forget to say, the first post is mine.. I have a problem with Firefox, and coockies and logins.. sorry for that..
Tanks for your support.. ;)
Locked
