I use more one screen whith laptop; If I disconnect the secondary screen while xnview was used on this screen beforehand, xnview opens outside the display area.
xnview display out of screen if move screen (multi-screen)
à quand XNView avec support Unicode ?
Re: xnview display out of screen if move screen (multi-screen)
yes a known issue
le support est basique dans XnView Classic, seul XnView MP a un support natifà quand XNView avec support Unicode ?
another critical problem with multiscreen and filter PAINT (1.06). After remove screen, must remove XPaint.ini.
otherwise it is impossible to access the window and XNview is frozen, forced to kill the process
Possible to not store XPaint position?
Had the same issue, this is how i solved it on Windows 7:
Set "ViewX" and "ViewY" to 0 in C:\Users\USER\AppData\Roaming\XnView\xnview.ini
Select Xnview, use ALT + SPACE, select move, use arrows key (one time) and with mouse move and clic on the desired position.
