Batch Conversion while in View mode
TheEvilHammer
Post by TheEvilHammer »
I've noticed that if you are in View mode, and you perform a batch conversion and place the resultant images in the same folder as the source images, the "Next File" and "Previous File" buttons do not find the new files. You have to close the tab for View mode and re-open View mode to see the new files.
Has anyone else seen this?
Re: Batch Conversion while in View mode
TheEvilHammer wrote:I've noticed that if you are in View mode, and you perform a batch conversion and place the resultant images in the same folder as the source images, the "Next File" and "Previous File" buttons do not find the new files. You have to close the tab for View mode and re-open View mode to see the new files.
Yes, right. The filelist is created only the first time.
