(All versions) Can't batch rename files when conflicts are present
cyberspectre
Post by cyberspectre »
XnView: MP 0.9 - 64 bit (Also on previous versions)
OS: Windows 64bit
Batch rename utility fails when files with conflicting names are present in the target directory
Effect: Error dialog - "An error occurred, files can't be renamed."
1. Create four files in the same directory, named as follows:
2. Attempt to use batch rename on file1.png.jpg and file2.png.jpg, replacing ".png.jpg" with ".jpg"
Actual behaviour (bug): Error dialog, no action performed :bug:
Expected behaviour: Confirmation dialog prompting overwrite of old files
Re: (All versions) Can't batch rename files when conflicts are present
yes currently destination files must not exist
