XnView MP 0.90
Locked
XnView MP 0.90
Please, don't post bugs or request in this topic!
You can download XnView MP 0.90 here:
Windows x32 ZIP version: http://download.xnview.com/XnViewMP-win.zip
Windows x32 SETUP version: http://download.xnview.com/XnViewMP-win.exe
  • SHA256: 5C250ACBB41A4E93AD3C12F57968770A79CE6FE418F5A5D61CC34FB12AD4064D
Windows x64 ZIP version: http://download.xnview.com/XnViewMP-win-x64.zip
Windows x64 SETUP version: http://download.xnview.com/XnViewMP-win-x64.exe
  • SHA256: D3FB8E818948051C68029CAF8EE18DF4CF4B30A313FC8277520E00E60CF08C76
For Windows 7 and older, you have to install the driver from DirectX to run correctly QtAV (audio/video)
Mac x64 TGZ version: http://download.xnview.com/XnViewMP-mac.tgz
Mac x64 DMG version: http://download.xnview.com/XnViewMP-mac.dmg
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version: http://download.xnview.com/XnViewMP-linux-x64.tgz
Linux x64 DEB version: http://download.xnview.com/XnViewMP-linux-x64.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP-0. ... 4.AppImage
Changelog 0.90:
1376: [New] Open XML file thumbnail support - viewtopic.php?f=82&t=37031
1374: [New] File list thumbnails + detail view
1369: [New] Search on others XMP fields - viewtopic.php?f=110&t=36957
1360: [New] Setting to disable drag&drop custom order
1357: [New] Resize 150% option - viewtopic.php?f=60&t=36496
1380: [Bug] Mosaic bug when using spacing - viewtopic.php?f=62&t=37069
1379: [Bug] File format color - viewtopic.php?f=82&t=37045
1378: [Bug] No message in Favorite menu if favorite doesn't exist - viewtopic.php?f=104&t=30769
1377: [Bug] XMP not correctly written by IPTC dialog
1375: [Bug] Slideshow: Bad image shown if click before end of animation
1373: [Bug] Split: Red grid not always visible - viewtopic.php?f=62&t=37012
1372: [Bug] Paint: Line not dotted with arrow - viewtopic.php?f=83&t=37011
1371: [Bug] Sometimes screenshot saved have 'read only' - viewtopic.php?f=62&t=36747
1370: [Bug] Update catalog doesn't read sidecar anymore - viewtopic.php?f=62&t=36977
1368: [Bug] 'create thumbnails for whole folder' - viewtopic.php?f=62&t=36961
1367: [Bug] Setting to choose 'save changes' - viewtopic.php?f=95&t=36242
1366: [Bug] Pan with Zoom setting - viewtopic.php?p=146522
1365: [Bug] Draw Tool removes metadata - viewtopic.php?f=95&t=36216
1364: [Bug] Can't undo in crop board - viewtopic.php?f=95&t=35858
1363: [Bug] Show info button not toggled - viewtopic.php?f=95&t=36612
1362: [Bug] Convert to jpg - filename with "_1" - viewtopic.php?f=95&t=36146
1361: [Bug] PSD thumbnail pixelated - viewtopic.php?f=95&t=36213
1359: [Bug] Ctrl+Right Click does not work on folders in the tree view - viewtopic.php?f=95&t=36952
1358: [Bug] Eyedropper cannot take the color for the 2ndary color - viewtopic.php?f=95&t=36863
1356: [Bug] Open .SLD - viewtopic.php?f=62&t=36953
1355: [Bug] No trackpad move on MacOSX - viewtopic.php?f=62&t=36947
Changelog 0.89:
1352: [New] Curves adjustment
1351: [New] Split - viewtopic.php?f=82&t=36813
0689: [New] Slideshow
1349: [New] Levels in Batch Convert
1346: [New] IPTC/XMP can be edited on RAW files
1345: [New] Windows default context menu by pressing CTRL key (thumbnails view)
1344: [New] Recursive mode and Synchronize Browser - viewtopic.php?f=60&t=35236
1332: [New] MegaPixels placeholder - viewtopic.php?f=60&t=35619
1354: [Bug] Empty folders left after move operations - viewtopic.php?f=62&t=36862
1353: [Bug] XMP sidecar not used loaded
1350: [Bug] Create/File listing: wrong output if field contains carriage return - viewtopic.php?f=62&t=36789
1348: [Bug] Current file not good after select tagged files - viewtopic.php?f=82&t=36735
1347: [Bug] MacOSX: saving doesn't use correct format
1343: [Bug] Category Sets not disabled when no selection
1342: [Bug] Bold text must be used in History/Suggested sets panel - viewtopic.php?f=62&t=36666
1341: [Bug] Rating and categories together not working - viewtopic.php?f=62&t=36678
1340: [Bug] Linux: Watermark problem - viewtopic.php?f=82&t=36684
1339: [Bug] Save selection between view tab - viewtopic.php?f=82&t=36669
1338: [Bug] No more thumbnails after rename folder - viewtopic.php?f=62&t=36571
1337: [New] Registration name/code in registry [HKEY_LOCAL_MACHINE\SOFTWARE\XnView\XnViewMP]
1336: [Bug] Can't use 'A', 'D' in view mode as shortcut - viewtopic.php?f=62&t=36606
1335: [Bug] Linux: Menu disappears - viewtopic.php?f=62&t=36623
1334: [Bug] Renaming subfolder is not changed in catalog - viewtopic.php?f=110&t=36410
1333: [Bug] Linux: Overwrite without warning - viewtopic.php?f=111&t=35910
1331: [Bug] MacOSX: Crash when switching from fullscreen view - viewtopic.php?f=62&t=36597
1330: [Bug] PDF/PS read problem on MacOSX
1328: [Bug] 'All' category returns empty list - viewtopic.php?f=83&t=36386
1327: [Bug] No info in statusbar for first file - viewtopic.php?f=62&t=36579
Changelog 0.88:
1326: [New] More used formats at the top in save dialog
1325: [New] Policy entries in xnview.ini
1312: [New] Exposure adjsutement in edit mode - http://newsgroup.xnview.com/viewtopic.php?t=36368
1304: [New] FLIF 0.3
1324: [Bug] Paint problem on scaled display - http://newsgroup.xnview.com/viewtopic.php?t=36458
1323: [Bug] 'Open With' & path with %1 - http://newsgroup.xnview.com/viewtopic.php?t=36538
1322: [Bug] Category 'Special items' doesn't use 'Match' setting - http://newsgroup.xnview.com/viewtopic.php?t=36386
1321: [Bug] Crash when using Mode dialog - http://newsgroup.xnview.com/viewtopic.php?t=36330
1320: [Bug] Catalog not correctly updated after folder renaming - http://newsgroup.xnview.com/viewtopic.php?t=36410
1319: [Bug] Batch convert: 'as original' format not restored
1318: [Bug] Batch convert doesn't keep creation date - http://newsgroup.xnview.com/viewtopic.php?t=36277
1317: [Bug] Linux: Database/default path problem - http://newsgroup.xnview.com/viewtopic.php?t=35447
1316: [Bug] CADIMAGE.DLL can't be used
1315: [Bug] Linux: Texts are gone - http://newsgroup.xnview.com/viewtopic.php?t=36326
1314: [Bug] Slow viewing of RAW files - http://newsgroup.xnview.com/viewtopic.php?t=36379
1311: [Bug] XnConvert should save/restore inactive actions - http://newsgroup.xnview.com/viewtopic.php?t=36252
1310: [Bug] Move To resets file date - http://newsgroup.xnview.com/viewtopic.php?t=35717
1309: [Bug] Slow batch rename with RAW files - http://newsgroup.xnview.com/viewtopic.php?t=36316
1308: [Bug] Collage problem - http://newsgroup.xnview.com/viewtopic.php?t=35979
1307: [Bug] Auto image size not kept - http://newsgroup.xnview.com/viewtopic.php?t=36276
1306: [Bug] {Filename] in 'File Listing' use pathname - http://newsgroup.xnview.com/viewtopic.php?t=36302
1305: [Bug] Empty categories after rename folder (base path) - http://newsgroup.xnview.com/viewtopic.php?t=36186
1303: [Bug] Transparent SVG - http://newsgroup.xnview.com/viewtopic.php?t=30579
1302: [Bug] Save selection & dot in filename - http://newsgroup.xnview.com/viewtopic.php?t=35910
1301: [Bug] 'Copy' in edit mode doesn't copy filename
Changelog 0.87:
1296: [New] Imgur service
1165: [New] Guetzli JPEG from Google - http://newsgroup.xnview.com/viewtopic.php?t=35158
1291: [New] Import&sort: new subfolder template
1287: [New] Zealous Crop - http://newsgroup.xnview.com/viewtopic.php?t=35860
1286: [New] Film simulation (clut from InstaCam)
1279: [New] Batch Convert - Start index for #
1275: [New] Setting for highlight selection - http://newsgroup.xnview.com/viewtopic.php?t=35808
1249: [New] Comment field (embbeded or description) - http://newsgroup.xnview.com/viewtopic.php?t=35281
0845: [New] Delete files or categories in browser - http://newsgroup.xnview.com/viewtopic.php?t=32816
1235: [New] Comment encoding - http://newsgroup.xnview.com/viewtopic.php?t=35542
1299: [Bug] Contact sheet unwanted spacing - http://newsgroup.xnview.com/viewtopic.php?t=36192
1298: [Bug] Batch rename and GPS special chars - http://newsgroup.xnview.com/viewtopic.php?t=36145
1297: [Bug] Thumbnail orientation after 'Edit IPTC' - http://newsgroup.xnview.com/viewtopic.php?t=36114
1295: [Bug] Resize dialog - Maximum size value in mm - http://newsgroup.xnview.com/viewtopic.php?f=79&t=35975
1295: [Bug] Resize dialog - Maximum size value in mm - http://newsgroup.xnview.com/viewtopic.php?t=35975
1294: [Bug] TIFF with 4 BitsPerSample - http://newsgroup.xnview.com/viewtopic.php?t=35961
1293: [Bug] Message when ghostscript is not found
1292: [Bug] Random msg: "This picture will be converted..." - http://newsgroup.xnview.com/viewtopic.php?t=35223
1290: [Bug] Rename on Folder tree bad focus - http://newsgroup.xnview.com/viewtopic.php?t=35922
1289: [Bug] Drag&Drop file in thumbnail view (empty space) should make a copy
1288: [Bug] Copy-Paste Auto-naming Discrepancy - http://newsgroup.xnview.com/viewtopic.php?t=35882
1285: [Bug] Annotation in contact sheet
1284: [Bug] Batch convert: Save and delete original - http://newsgroup.xnview.com/viewtopic.php?t=35670
1283: [Bug] 'Fixed ratio' should be set with image ratio - http://newsgroup.xnview.com/viewtopic.php?t=35848
1282: [Bug] Sort in view mode not always correct - http://newsgroup.xnview.com/viewtopic.php?t=35832
1281: [Bug] Favorites pane sometimes empty - http://newsgroup.xnview.com/viewtopic.php?t=35834
1280: [Bug] PSD thumbnail support - http://newsgroup.xnview.com/viewtopic.php?t=35810
1278: [Bug] Crash after file(s) are deleted or moved - http://newsgroup.xnview.com/viewtopic.php?t=35462
1277: [Bug] Batch Convert: Save 'Delete' question choice
1276: [Bug] "Update catalog from files" remove categories - http://newsgroup.xnview.com/viewtopic.php?t=35698
1274: [Bug] Copy instead of move in the same share - http://newsgroup.xnview.com/viewtopic.php?t=35504
1273: [Bug] Import category list - http://newsgroup.xnview.com/viewtopic.php?t=35741
1272: [Bug] Custom order doesn't reset header indicator - http://newsgroup.xnview.com/viewtopic.php?t=35296
1271: [Bug] Sidecar: Export Rating/label doesn't export categories - Export categories doesn't export rating/label
1270: [Bug] Update catalog needs 'Import subject' setting - http://newsgroup.xnview.com/viewtopic.php?t=35698
1269: [Bug] Renaming video file in use - http://newsgroup.xnview.com/viewtopic.php?t=35254
1268: [Bug] XnView MP can rename files to too long names - http://newsgroup.xnview.com/viewtopic.php?t=34411
1267: [Bug] Tabbing impossible in dialogs with multi-line fields - http://newsgroup.xnview.com/viewtopic.php?t=35244
1266: [Bug] Compare - shortcut & selection - http://newsgroup.xnview.com/viewtopic.php?t=35592
1265: [Bug] Create "joining images" based on DNG ignoring the embedded preview - http://newsgroup.xnview.com/viewtopic.php?t=35645
1232: [Bug] Fullscreen: "Quit" closes program - http://newsgroup.xnview.com/viewtopic.php?t=30824
1263: [Bug] Batch convert - Canvas resize interface - http://newsgroup.xnview.com/viewtopic.php?t=35793
1264: [Bug] GPS tag missing - http://newsgroup.xnview.com/viewtopic.php?t=35690
1262: [Bug] "Maximum of view tabs" option is ignored sometimes - http://newsgroup.xnview.com/viewtopic.php?t=35247
1261: [Bug] "View » Reset X/Y" does not work - http://newsgroup.xnview.com/viewtopic.php?t=35552
1260: [Bug] Category assignment - http://newsgroup.xnview.com/viewtopic.php?t=35584
1259: [Bug] Crash when pressing <Ctrl> + </> in Browser-Mode with folder selected - http://newsgroup.xnview.com/viewtopic.php?t=35628
1258: [Bug] Moving a folder on itself in Detail View - http://newsgroup.xnview.com/viewtopic.php?t=35370
1257: [Bug] Theme not checked - http://newsgroup.xnview.com/viewtopic.php?t=18636
1256: [Bug] Preview and Browser navigation issues with videos - http://newsgroup.xnview.com/viewtopic.php?t=35222
1255: [Bug] Mac folder numeric sorting - http://newsgroup.xnview.com/viewtopic.php?t=34548
1254: [Bug] Selection ratio in main menu and crop toolbar out of sync - http://newsgroup.xnview.com/viewtopic.php?t=35526
1253: [Bug] Slide show: Same image shown multiple times - http://newsgroup.xnview.com/viewtopic.php?t=35062
1252: [Bug] Drag and drop doesn't work in List view - http://newsgroup.xnview.com/viewtopic.php?t=35297
1251: [Bug] PSB format - http://newsgroup.xnview.com/viewtopic.php?t=34134
1250: [Bug] Restoring layout reverts info pane tab - http://newsgroup.xnview.com/viewtopic.php?t=35088
1248: [Bug] Manual refresh doesn't refresh folder tree - http://newsgroup.xnview.com/viewtopic.php?t=35075
1247: [Bug] Toolbar item "show files in subfolder" doesn't show stat - http://newsgroup.xnview.com/viewtopic.php?t=29652
1246: [Bug] Browser: Menu "Edit > Properties" missing - http://newsgroup.xnview.com/viewtopic.php?t=33970
1079: [Bug] Wrong multi-selection after mouse wheel selection - http://newsgroup.xnview.com/viewtopic.php?t=34719
1245: [Bug] Bug when selecting files with the keyboard - http://newsgroup.xnview.com/viewtopic.php?t=33945
1244: [Bug] UI: Slash in path - http://newsgroup.xnview.com/viewtopic.php?t=34392
1243: [Bug] Resizing problem - http://newsgroup.xnview.com/viewtopic.php?t=31350
1242: [Bug] Copy Image does not work - http://newsgroup.xnview.com/viewtopic.php?t=34652
1241: [Bug] Thumbs+Details: Strange behaviour when Renaming - http://newsgroup.xnview.com/viewtopic.php?t=35225
1240: [Bug] Reset fit when next/previous file - http://newsgroup.xnview.com/viewtopic.php?t=34416
1239: [Bug] Results of scanning aren't added to the browser - http://newsgroup.xnview.com/viewtopic.php?t=34446
1238: [Bug] Add Noise filter does not respect the mask - http://newsgroup.xnview.com/viewtopic.php?t=35061
1237: [Bug] Artefacts when high quality zooming 4-color greyscale - http://newsgroup.xnview.com/viewtopic.php?t=35064
1236: [Bug] Large image thumbnail problem - Thumbnail of large images are dark
1234: [Bug] Hierarchy not saved in IPTC keywords - http://newsgroup.xnview.com/viewtopic.php?t=35755
1233: [Bug] Darkened screen when closing context menu - http://newsgroup.xnview.com/viewtopic.php?t=35104
1231: [Bug] Keyboard shortcuts "fast image scrolling" missing - http://newsgroup.xnview.com/viewtopic.php?t=33224
1230: [Bug] Details View: Middle Mouse Click Doesn't Open File - http://newsgroup.xnview.com/viewtopic.php?t=33618
1229: [Bug] When the Favourite is non-existent - http://newsgroup.xnview.com/viewtopic.php?t=30769
1228: [Bug] Database search progress not indicated - http://newsgroup.xnview.com/viewtopic.php?t=35095
1227: [Bug] "Shadow" & "Conbright" don't respect selection - http://newsgroup.xnview.com/viewtopic.php?t=35193
1226: [Bug] Video volume is changed when changing mode - http://newsgroup.xnview.com/viewtopic.php?t=35331
1225: [Bug] Status bar not updated with 1st file at beginning - http://newsgroup.xnview.com/viewtopic.php?t=35175
1224: [Bug] Purge 'Most recently used files&dirs' on exit - http://newsgroup.xnview.com/viewtopic.php?t=16966
1223: [Bug] Focus lost after searching - http://newsgroup.xnview.com/viewtopic.php?t=35177
1222: [Bug] Symbolic directory link - http://newsgroup.xnview.com/viewtopic.php?t=34417
1221: [Bug] Volume doesn't always mute when at zero - http://newsgroup.xnview.com/viewtopic.php?t=34888
1220: [Bug] Tree navigation with keyboard issue - http://newsgroup.xnview.com/viewtopic.php?t=35329
1219: [Bug] Image "jumps" when selecting requires scrolling - http://newsgroup.xnview.com/viewtopic.php?t=34969
1218: [Bug] Autoexpand subfolders in folder tree - http://newsgroup.xnview.com/viewtopic.php?t=35293
1217: [Bug] Disable catalog - http://newsgroup.xnview.com/viewtopic.php?t=35521
1216: [Bug] Thumbnail for folder's link - http://newsgroup.xnview.com/viewtopic.php?t=33943
1215: [Bug] .jpg_original files after editing metadata - http://newsgroup.xnview.com/viewtopic.php?t=35404
1214: [Bug] Multi-selection in browser: Wrong state of menu items - http://newsgroup.xnview.com/viewtopic.php?t=35346
1213: [Bug] Wrong thumbnail orientation for raw files - http://newsgroup.xnview.com/viewtopic.php?t=35511
1212: [Bug] Batch renaming, enter key problem - http://newsgroup.xnview.com/viewtopic.php?t=35260
1211: [Bug] HLS-Temperature don't use selection rectangle - http://newsgroup.xnview.com/viewtopic.php?t=35251
1210: [Bug] No Drag&Drop to parent folder - http://newsgroup.xnview.com/viewtopic.php?t=34871
1209: [Bug] Manually set video position ignored - http://newsgroup.xnview.com/viewtopic.php?t=35292
1208: [Bug] Thumbnails+filenames view: Filename truncated - http://newsgroup.xnview.com/viewtopic.php?t=35258
1207: [Bug] View mode doesn't detect file removed - http://newsgroup.xnview.com/viewtopic.php?t=35435
1206: [Bug] Keep Ratio and Preset Sizes Issues - http://newsgroup.xnview.com/viewtopic.php?t=35548
1205: [Bug] No message box "...will lose all existing metadata" - http://newsgroup.xnview.com/viewtopic.php?t=35429
1204: [Bug] Change EXIF orientation field when EXIF doesn't exist - http://newsgroup.xnview.com/viewtopic.php?t=35749
1203: [Bug] Remove file on Linux sometimes doesn't work - http://newsgroup.xnview.com/viewtopic.p ... 8&p=142932
1202: [Bug] Batch convert watermark: when watermark is bigger than image + right position
1199: [Bug] Can't disable 'format color' on Thumbnails+label mode
1200: [Bug] Edit GPS change always the file date - http://newsgroup.xnview.com/viewtopic.php?t=35682
1198: [Bug] Settings in Registry - http://newsgroup.xnview.com/viewtopic.php?t=35603
1196: [Bug] TIF > 2GB & multipage - http://newsgroup.xnview.com/viewtopic.php?t=35056
dietmar
Re: XnView MP 0.90
Post by dietmar »
Pierre,
what does it mean that Linux 32-bit is stricken through? Isn't this supported any more?
If you download the 32-bit Linux version from the web site, it will install 0.89.
Regards
Dietmar
Re: XnView MP 0.90
dietmar wrote: what does it mean that Linux 32-bit is stricken through? Isn't this supported any more?
currently the 32bits versions are not downloaded a lot, so only 0.89
dietmar
Re: XnView MP 0.90
Post by dietmar »
xnview wrote:currently the 32bits versions are not downloaded a lot, so only 0.89
I understand. You should add a note to the website which says "Download 0.90".
And while I understand that other versions are more important, keep in mind that re-using old 32-bit computers is a main reason for using Linux.
Thanks for the great work
Dietmar
KiboOst
Re: XnView MP 0.90
Post by KiboOst »
I've downloaded xnviewMP 0.90 zip (portable).
Works fine, and in about it does show v0.90 (Mar 4 2018)
Anyway the xnviewmp.exe is still in noted version 0.89.0.0
This is annoying whith some scripts that check the file version to know if it should update or not.
deus-ex
Re: XnView MP 0.90
Post by deus-ex »
Dear Pierre,
I just wanted to bring to your attention that your online change log for XnViewMP v0.90 still reports it as "not yet released".
Ratteler
Re: XnView MP 0.90
Post by Ratteler »
OS X 10.9.5 Mavericks no longer supported?
XnView MP 0.90 is the only piece of software that claims it no Longer supports Mavericks.
Is there any reason why it's no longer supported?
Is there still a link to XnView MP 089? Because I think this is the highest version of the OS my machine can support.
...and shouldn't a change like that at least be mentioned in the changelog or on the download page?
deus-ex
Re: XnView MP 0.90
Post by deus-ex »
Re: XnView MP 0.90
Ratteler wrote: Sat Jul 14, 2018 3:04 am OS X 10.9.5 Mavericks no longer supported?
XnView MP is based on QT library, and lastest version doens't support anymore 10.9 :(
grem
Re: XnView MP 0.90
Post by grem »
Hello, Pierre.
Could you copy XnViewMP-linux-x64.tgz file of latest version XnViewMP-0.90 to https://download.xnview.com/old_versions/
with naming it as usual, i.e. as XnViewMP-090-linux-x64.tgz ?
P.S.
If 0.91 release is expected soon, please, make it's versioned copy to that place too.
Thank you in advance.
Locked
