0.89: [EDITED] importing hierarchical keyword problem
mahikeulbody
Post by mahikeulbody »
XnView MP Linux
Version 0.89 64bits (Jan 15 2018)
Short description: importing a file with a xmp keywords with "|" separator creates the corresponding DB hierarchy but set the photoonly with the last item of the hierarchy (even if 'automatically apply parent keywords' option is set).
Effect: filtering on a category don't show the files of the categories children of the selected one.
1. set 'automatically apply parent keywords'
2. import a file test with dc:subject[1] = Lieux|France|Auvergne Rhône-Alpes|38112 Méaudre|lieu indéfini (see file attached)
3. open the filter categories panel
4. select a parent category such as 'France' or 'Auvergne Rhône-Alpes'
Actual behaviour (bug): none file is shown
Expected behaviour: file test should be shown (at least if 'automatically apply parent keywords' option is set)
mahikeulbody
Re: 0.89: automatically apply parent keywords setting problem
It is the same behaviour importing hierarchical tags such as lr:hierarchicalSubject[].
May be it is not really a bug but a missing feature : automatically set parent keywords to hierarchical imported keywords.
currently 'automatically apply parent keywords' setting is only for category view pane, not importing
