0.89: Ctrl+Right Click does not work on folders in the tree view
arspr
Post by arspr »
Well, just that. Ctrl+Right Click is just like Right Click on the folders of the tree view....
Re: 0.89: Ctrl+Right Click does not work on folders in the tree view
arspr wrote:Well, just that. Ctrl+Right Click is just like Right Click on the folders of the tree view....
you would like the windows explorer popup menu?
arspr
Post by arspr »
Yes, exactly as you do with files/images.
But take in mind that Windows context menu is different when you Right Click on a folder in the Folder Tree than when you do on the right panel... So, Ctrl+Right Click on Folder Tree should bring up windows folder tree one.
See issue for current status and some details. I'll post here once the problem has been fixed.
This problem is supposed to be fixed in XnView MP 0.90. Please check and confirm the bug fix here.
arspr
Post by arspr »
Oooops, I missed this one...
Confirmed that it works in 0.91b4. You can close it.
