0.89: Ctrl+Right Click does not select the image
arspr
Post by arspr »
XnView: MP 0.89 - 64 bit
OS: Windows 64bit
Well, complementary of viewtopic.php?f=62&t=36950
Ctrl+Right click on an unselected image brings System context menu on your previously selected image. (Or none at all if you don't have a previously selected file).
(OTOH if you Right click on an unselected item, two things happen: 1. it is firstly selected, and then 2. XnView context menu appears).
Effect: Incoherent behaviour
1. Select an image (left click on it)
2. Ctrl+Right click on ANY other image... System context menu appears... but for your first item.
3. (Repeat but Right click and compare what happens).
Re: 0.89: Ctrl+Right Click does not select the image
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
arspr
Post by arspr »
Sadly, not fixed... (at least in detail view). 0.91b4
arspr wrote: Mon Aug 06, 2018 10:45 am Sadly, not fixed... (at least in detail view). 0.91b4
it works for me
arspr
Post by arspr »
Strange. What can I do to test it more deeply?
(Moreover: I had completely missed your solution to my related previous request: Ctrl+Right Click working on folder tree. Well, it PERFECTLY works there. It exactly works as normal Right Click: it temporally selects that new folder, shows either the system menu or XnView one, and then it deselects it so you don't actually change your browsed folder).
arspr
Post by arspr »
This issue is still alive with 0.93...
I've made a deeper test and this issue ONLY happens within:
  • Detailed view
  • Thumbnails + Detail view
In any other view it perfectly works.
This problem is supposed to be fixed in XnView MP 0.98.0. Please check and confirm the bug fix here.
