Windows 3.1x support !?
vanden
Post by vanden »
In the "ReadMe.txt" file of XnView v2.43 it is written:
Platforms
PC x86 Windows 3.1x, 95, 98, NT, Me, 2000, XP, Vista, 7, 8.1, 10
But in reality the latest version I found that works with Win3.11 is the 1.15
Old versions found here: https://download.xnview.com/old_versions/
All later versions do not work: the version with install make a Win32s error when launching the installer, the zip version also make a Win32s error when launching ...
So what is the latest Win3.1x compatible version?
Should not it remove the Win3.1x compatibility of the "ReadMe.txt" file?
Re: Windows 3.1x support !?
yes, 1.15 was the lastest i think. It's only the list of platforms that was/are used
vanden
Post by vanden »
Finally I found a version 1.50 for Win3.11 (on the page download.xnview.com named Xnview-wfw.zip)
By cons I can not change the language on version 1.15 (in Option/Language only English appears), on Win10 it works.
And on version 1.50 I have an error every time I go in option :
Then XnView quits and then I restart it Win3.11 crash.
By cons we can adjust the options through the file XNVIEW.INI (including switch to French for version 1.50)
sorry but i can't help, i have no more a Windows 3.1
vanden
Post by vanden »
I have another problem, AVAST and AVG find a virus in xnviewde.dll and xnviewfr.dll files (Xnview 1.50) :
https://www.virustotal.com/fr/file/ea6e ... 513350950/
Is it a false positive ?
vanden wrote: Is it a false positive ?
yes
vanden
Post by vanden »
OK, Thanks
Finally I found the problem.
This is because of DosBox when using a folder to mount the virtual hard disk. Using a disk image and "option" works properly :D
