Save Selection Broken?
Mike Truly
Post by Mike Truly »
Latest MP
If I use Edit>Set Selection Size>Save Selection then crop the picture... it crops fine.
If I open another picture and try to use Restore Selection, the selection is not restored.
I recently started using MP instead of Classic so maybe I'm doing something wrong.
Thanks!
Sincerely,
Mike Truly
Truly Media
http://www.trulymedia.com
Re: Save Selection Broken?
how do you open the other picture? Next file?
Mike Truly
Sorry, I should have been more clear.
I do a CTRL+SHIFT+V to paste a 1st screengrab into MP.
I select a region.
I do an Edit>Set Selection Size>Save Selection.
I crop 1st screengrab to the selected size.
I do a CTRL+SHIFT+V to paste a 2nd screengrab into MP. (2nd screengrab is same size as 1st screengrab).
I do an Edit>Set Selection Size>Restore Selection.
No selection is restored.
I used this function a lot in Classic to crop multiple screengrabs to the same size.
Thanks!
Sincerely,
Mike Truly
Truly Media
This problem is supposed to be fixed in XnView MP 0.89. Please check and confirm the bug fix here.
Mike Truly
Thanks very much for this fix... it seems to be working as desired in the beta.
Thanks again.
Sincerely,
Mike Truly
Truly Media
