XnView 2.41
Locked
XnView 2.41
Dear user,
XnView 2.41 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
http://download.xnview.com/XnView-win.exe (English Setup, Multi language)
http://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
http://download.xnview.com/XnShellEx.exe
http://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
http://download.xnview.com/XnShellEx64.exe
http://download.xnview.com/XnShellEx64.zip
SHA256:
XnView-win.exe: 52AED77E70A7B35FA77881FE7AE9D432A33F9261E765D1288A7E1E8C8B88B6AA
XnView-win.zip: 19F08046E15CA3EF14E1B7D7EE73C98B58F35EA9BBF936782A42CBBB318956A8
XnView-win-full.exe: 4594A8B8D2FDFD7378D2776675BE5047E6CC8D77511A0137CCD1F247FDCC39F7
XnView-win-full.zip: F82B37C297394499169A9AF8AB5E2F0CB3C10AD73A1844E7E8DD0C7CF1C2C678
XnView-win-small.exe: 4C4BDD315A57D00A67680E7517DCA9F0D5E484599276907684C6478EE1D4C54A
XnView-win-small.zip: 68B140F102E5B24E44708531A6B0D9FBFBFC87309DBFE310E1CB1EB5439CE41A
____ 2.41 Changelog
Basic support for unicode filename
2Gb limitation on 64bits OS - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35165
Displaying RGBA image without use alpha - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35809
Print TIFF with orientation flag in browser - http://newsgroup.xnview.com/viewtopic.php?f=36&t=36197
GIF loop not saved in .sld - http://newsgroup.xnview.com/viewtopic.php?f=35&t=35991
Clip support - http://newsgroup.xnview.com/viewtopic.php?f=34&t=28554
Slideshow crash on RAW files - http://newsgroup.xnview.com/viewtopic.php?f=36&t=34632
TIF > 2GB & multipage - http://newsgroup.xnview.com/viewtopic.php?f=79&t=35056
RGBA printing
Thumbnails upscaling - http://newsgroup.xnview.com/viewtopic.php?f=35&t=36090
NConvert: -keepdocsize fixed
NConvert: -shadow - http://newsgroup.xnview.com/viewtopic.php?f=57&t=36163
NConvert: -align - http://newsgroup.xnview.com/viewtopic.php?f=57&t=36164
____ 2.40 Changelog
CMYK image default color profile - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31685
http://newsgroup.xnview.com/viewtopic.php?f=35&t=28839
RGBA resize (bilinear) - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33425
http://newsgroup.xnview.com/viewtopic.php?t=29238
http://newsgroup.xnview.com/viewtopic.php?t=34493
Ctrl+RMB to copy color - http://newsgroup.xnview.com/viewtopic.php?p=141793
Capture rectangle on second monitor - http://newsgroup.xnview.com/viewtopic.php?f=56&t=32892
Print 50+ via command line - http://newsgroup.xnview.com/viewtopic.php?f=35&t=35350
Filelist to print - http://newsgroup.xnview.com/viewtopic.php?f=34&t=35378
LIBPNG 1.6.29
SQLite 3.18.0
ZLIB 1.2.11
LCMS 2.8
BMP 2+10+10+10 - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32577
Category removed if delete file - http://newsgroup.xnview.com/viewtopic.p ... 2&start=15
Category moved with Cut/Paste
8BF & undo - http://newsgroup.xnview.com/viewtopic.php?f=36&t=34508
'Purge Now' - http://newsgroup.xnview.com/viewtopic.php?f=34&t=32667
OpenEXR updated - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33039
Resize gamma correction - http://newsgroup.xnview.com/viewtopic.php?f=34&t=33273
Change timestamp & DST - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33483
Selection + Tab - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33983
GIF loop - http://newsgroup.xnview.com/viewtopic.php?f=35&t=34036
PAM format - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35132
JPEG 2000 - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35277
Maximize on first monitor - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32343
Resize default size - http://newsgroup.xnview.com/viewtopic.php?f=34&t=33694
PEF for thumbnail's folder - http://newsgroup.xnview.com/viewtopic.php?f=35&t=35363
Cancel removed from Setup wizard - http://newsgroup.xnview.com/viewtopic.php?f=34&t=32958
Previous/Next file & RecognizeByExt == false - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33127
Next/Previous & video - http://newsgroup.xnview.com/viewtopic.php?f=36&t=35182
Better dialog for update - http://newsgroup.xnview.com/viewtopic.php?f=34&t=19950
WebP plugin updated
OpenJPEG2000 updated
RIOT addon updated
PNGOUT updated
X3F with only embedded JPEG
NConvert: text with -text_rotation - http://newsgroup.xnview.com/viewtopic.php?f=57&t=35441
NConvert: -text_border added
____ 2.39 Changelog
no IPTC fields in tooltip/info
Thumbnail for blend file
____ 2.38 Changelog
Sort by exif - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32387
Zooming instead file navigation - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33917
____ 2.37 Changelog
Better HiDPI support
Change timestamp and video
GPS direction - http://newsgroup.xnview.com/viewtopic.php?f=35&t=33587
Right click (make selection) and delete - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33700
NConvert: Multipage extract - http://newsgroup.xnview.com/viewtopic.php?f=57&t=33879
____ 2.36 Changelog
FLIF format added
SVG support via rsvg-convert.exe - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31748
Search similar & extension - http://newsgroup.xnview.com/viewtopic.php?f=56&t=32840
Multipage save doesn't use read settings
PCT crash - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33025
NConvert: -t start step for number in output name
____ 2.35 Changelog
#THUMB_WIDTH_MAX# & #THUMB_HEIGHT_MAX# - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30652
JPEGXR
Backspace not working in fullscreen
LibPNG 1.6.20
ZIPPack Addon - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31563
Moderator & Librarian
Re: XnView 2.41
xnview wrote:Basic support for unicode filename
The following tests were done on an English-language Windows XP Professional SP3:
XnView MP v084 x32
XnView MP v084 x32
XnView Classic v2.41
I used the “native names” from Wikipedia's list of ISO 639-1 codes to create files and folders with Unicode characters…
Arabic – العربية
العربية – Arabic
Chinese (S) – 简体中文
简体中文 – Chinese (S)
Chinese (T) – 繁體中文
繁體中文 – Chinese (T)
Czech – Čeština
Čeština – Czech
Farsi – فارسی
فارسی – Farsi
French – Français
Français – French
Greek – ελληνικά
ελληνικά – Greek
Hebrew – עברית
עברית – Hebrew
Japanese – 日本語
日本語 – Japanese
Korean – 한국어
한국어 – Korean
Russian – Русский
Русский – Russian
… and put a copy of…
… in every directory.
obelisk
Re: XnView 2.41
Post by obelisk »
Can you tell me the plan classic vs MP?
now that this has unicode, and better folder support than MP, I really don't know what I should do.
Re: XnView 2.41
obelisk wrote:Can you tell me the plan classic vs MP?
XnView has not unicode support only a basic support
LittleDoggie
Re: XnView 2.41
Post by LittleDoggie »
Four of the six SHA256 checksums haven't been updated. You are listing the same checksums that you listed for version 2.40.
Re: XnView 2.41
LittleDoggie wrote:Four of the six SHA256 checksums haven't been updated. You are listing the same checksums that you listed for version 2.40.
right fix
obelisk
Re: XnView 2.41
Post by obelisk »
Oh, but it can now show unicode files.
Because MP cannot do companion files, and can't show thumbs for linked folders, I have to rely on classic and run both. This may mean I can just use classic.
pic_viewer
Re: XnView 2.41
Post by pic_viewer »
Still completely fails with Thai.
clonedone
Re: XnView 2.41
Post by clonedone »
Thank you for fixing the gif loop feature!!!
Locked
