0.87 Beta1: Batch renaming is not possible on movies
arspr
Post by arspr »
XnView: MP 0.87 beta 1 /64 bit
OS: Windows 10 - 64bit
Well, the titles says it all.
In fact, I had already posted this issue in this solved bug thread.
I thought it was the very same issue as the parent one. But it seems it's not. 0.87 beta 1 has effectively solved the first issue but not the second one.
Effect: You cannot rename several movie files at once.
1. Select several movie files.
2. Press F2 to batch rename.
3. Press OK and look what happens.
Actual behaviour (bug): You get the strange error message.
Expected behaviour: Files should be renamed.
Re: 0.87 Beta1: Batch renaming is not possible on movies
no problem here, what do you have?
arspr
Post by arspr »
I'm running 0.87 Beta 2 (I've just updated) on Windows 10 1703 64-bit fully updated.
I still get the error. Look at the very first two screenshots.
More over, the ORIGINAL PARENT BUG is also not solved. I didn't properly test before, sorry. But now I get a different error, and also different from the batch rename one. Look at last two screenshots...
What more info can I provide? Is there a "log file" or something like that I could upload?
... the error continues..jpg (8.31 KiB) Viewed 3570 times
Ooops. The error also happens when trying to rename a single file from player....jpg
Ooops. The error also happens when trying to rename a single file from player....jpg (11.23 KiB) Viewed 3570 times
... But the error message is different.jpg (8.37 KiB) Viewed 3570 times
arspr
Post by arspr »
I suppose, it's expected but Beta 3 has not solved either issue:
  • Batch renaming is not possible on movies. (The first two screenshots of the former post).
  • Renaming is not possible from XnView Video Player. (The last two screenshots of the former post).
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
arspr
Post by arspr »
Hi, I had missed this new version!!!
Mixed results with 0.91b4:
  • Batch renaming works fine with movies now.
  • But I still get the very same error while trying to rename within XnView built-in movie player...
arspr
Post by arspr »
The issue is still active within built-in video player in 0.93.
If I Open a video file, press F2 and try to rename I get the "An error occurs during rename!".
arspr wrote: Sat Feb 02, 2019 6:47 am The issue is still active within built-in video player in 0.93.
Ok, so the original problem is fixed. Currently you can't rename an opened video file
arspr
Post by arspr »
xnview wrote: Sat Feb 02, 2019 8:44 am
Exactly. Nevertheless you have pictures of the error in the third post.
