[Feature Request] G.I.M.P.'s "Zealous Crop"
bdragon
Post by bdragon »
Okay, i just understood what Gimp's zealous crop does and i would like to experiment with it on a large scale. Is it possible to implement in XnConvert?
Basically it searches for lines or columns of identical colors inside of the image and removes them, This usually removes whitespaces between panels in a comic (but only for very formulaic comics with vertical and horizontal lines between panels, as it does not seek diagonals) or blank spaces (again vertical and horizontal only) in an image making it "more compact".
It also basically destroys any composition inside the image, so It's not something for people who want to keep the image as it was originally. But it's an interesting feature i'd like to experiment with.
It is mighty useful for those (like me) who find it annoying that after scanning a page of text a single "spec" has stopped cropping the page to a good size and your text is all on one corner because of that single spec (like a clip/fastener/clamp on a corner and such, so not exactly something a noise remover might catch, but it is enough of a something that a quick checking of the images before batch cropping might have missed).
However if it might not be too much i would also like to ask for a bit of customization options, which might turn useful, because while i don't mind it removing the whitespace between paragraphs, i do not like it removing line spacing completely inside the same paragraph.
Let me know if it is possible, i know that for gimp it is very much time consuming, but i'd like to experiment with this feature on a batch scale, and gimp does not allow me to do that.
Re: [Feature Request] G.I.M.P.'s "Zealous Crop"
you have 'auto crop'
bdragon
Post by bdragon »
auto crop just checks the "outside" of the picture. Check the zealous crop.
https://docs.gimp.org/en/plug-in-zealouscrop.html
will be added in next version
bdragon
Post by bdragon »
Looking forward to it. Thanks.
knightdj
Post by knightdj »
i can not find this new feature? is it working
knightdj wrote:i can not find this new feature? is it working
already in version, image menu
pglpmxn
Post by pglpmxn »
Writing in 2025 with XnView MP 1.8.6 64-bit (Linux) - Libformat 7.204:
I cannot find a "Zealous Crop" item under the Image menu. Nor do I see a "Zealous Crop" checkbox when the Crop bar appears. Have they been removed? Or do I need to activate them somehow? Cheers!
In XnView MP it is a Batch convert option, recently bizarrely moved to a new Actions > Transform heading... :wink:
pglpmxn
Post by pglpmxn »
cday wrote: Thu Mar 13, 2025 7:55 am In XnView MP it is a Batch convert option, recently bizarrely moved to a new Actions > Transform heading... :wink:
Thank you!! A bit inconvenient that one must go through batch, but I'm glad it's available :)
