Renaming a file in the <search results> not possible
Locked
jens116
Post by jens116 »
If you try to rename a single file in the <search results> the action is refused by an "error renaming the file ..."
Re: renaming a file in the <search results> not possib
jens116 wrote:If you try to rename a single file in the <search results> the action is refused by an "error renaming the file ..."
Ok, a known bug
Helmi
Renaming files in the <search results> caused deletion
Post by Helmi »
The "error renaming the file ..." I found in an older version.
In the Version 1.70.4 I selected some files in the <search result> window (Files from different subfolders). Then I pressed F2 for the rename batch dialog. I selected <Filename No Ext> and added a short prefix.
After this action the Thumbnail-names seemed to be not renamed but when I selected one of the "batch renamed" files there was no bigger view and no reaction on doubleclick. :?
The files seems to be automatically deleted insteadt of renamed. :(
I couldn't find them in the original folders neither then on one of my other drives. They are definitly gone, but don't bother they where not so necessary because I have a copy somewhere.
The former search dialog is finding now an amount without the number of my "renamed" files.
Re: Renaming files in the <search results> caused dele
Helmi wrote:The "error renaming the file ..." I found in an older version.
Strange, after the batch rename, you must have always your files, but perhaps (a bug?) not in the original folder...
Locked
