0.83: .psb file format support
thibaud
Post by thibaud »
it seems that xnviewMP has difficulties displaying photoshop .psb file format.
there's a good chance that this may be with newer .psb files only as I don't recall seing problems before.
Moderator & Librarian
Re: .psb file format support
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=132803#p132803]Photoshop .psb format support[/url]) wrote:
thibaud wrote:
xnview wrote:could you send me a sample file?
this sample gives an error:
http://www.fileformatcommons.com/psb-file-format/
I have a problem to read this sample, but PSB from photoshop is supported
XnView Classic v2.39 opens ffc.psb as a solid black square (24-bit 500×500). MP v.83 says: “File can't be loaded!”
[color=green]psdparse.exe -v ffc.psb[/color] wrote:
Processing "ffc.psb"
  PSB (version 2), 3 channels, 500 rows x 500 cols, 8 bit RGBColor
  (color mode data is empty)
  ...skipped image resources (30028 bytes)
2 layers:
  layer 0: (   0,   0, 500, 500), 3 channels ( 500 rows x  500 cols)
    channel  0:    7002 bytes, id= 0  (R)
    channel  1:    7002 bytes, id= 1  (G)
    channel  2:    7002 bytes, id= 2  (B)
  (extra data: 324 bytes @ 30144)
  (no layer mask)
  ...skipped layer blending ranges (40 bytes)
  layer 1: ( 106,  95, 355, 429), 4 channels ( 249 rows x  334 cols)
    channel  0:   30499 bytes, id=-1  (transparency mask)
    channel  1:    2990 bytes, id= 0  (R)
    channel  2:    2990 bytes, id= 1  (G)
    channel  3:    2990 bytes, id= 2  (B)
  (extra data: 11892 bytes @ 30542)
  (no layer mask)
    name: "File Format Commons psb  010001"
## layer data begins @ 42434
## layer image data begins @ 42434
  layer 0 ("Background"):
  blending mode: sig='8BIM' key='norm'(normal) opacity=255(100%) clipping=0(base)
    flags=0x9(transp_prot(1) visible(0) bit4valid(1) pixel_data_irrelevant(0))
  channel 0:
>>> channel id =  0 @   42434, 7002 bytes
    compression = 1 (RLE)
    uncompressed size 250000 bytes (row bytes = 500)
  channel 1:
>>> channel id =  1 @   49436, 7002 bytes
  channel 2:
>>> channel id =  2 @   56438, 7002 bytes
  layer 1 ("File Format Commons psb  010001"):
    flags=0x8(transp_prot(0) visible(0) bit4valid(1) pixel_data_irrelevant(0))
  channel 0:
>>> channel id = -1 @   63440, 30499 bytes
    uncompressed size 83166 bytes (row bytes = 334)
  channel 1:
>>> channel id =  0 @   93939, 2990 bytes
  channel 2:
>>> channel id =  1 @   96929, 2990 bytes
  channel 3:
>>> channel id =  2 @   99919, 2990 bytes
## end of layer image data @ 102909
  (global layer mask info section is empty)
  merged image:
>>> merged image data @  242842
    uncompressed size 750000 bytes (row bytes = 500)
  done.
p135868.zip
Sample PSB + extracted layers + psdparse logfile
(44.41 KiB) Downloaded 139 times
thibaud wrote:it seems that xnviewMP has difficulties displaying photoshop .psb file format.
Could you please send me a psb sample?
thibaud
Post by thibaud »
If you can't read [the above] sample I suppose it means something isn't right
See Issue 1024 for details.
thibaud
Re: 0.83: .psb file format support
Post by thibaud »
I suppose this fix didn't make it into 0.84 beta 1 yet. (still not working)
thibaud wrote:I suppose this fix didn't make it into 0.84 beta 1 yet.
No, 0.84 beta 1 is dated 18 Nov 2016...
0.84 is supposed to support .psb files. Could you please check and confirm, thibaud?
The second of the two layers (#0 + #1) of ffc.psb named “File Format Commons psb 010001” is supposed to have a transparency mask. XnView MP v0.84 displays it as fully opaque.
XnTriq wrote:The second of the two layers (#0 + #1) of ffc.psb named “File Format Commons psb 010001” is supposed to have a transparency mask. XnView MP v0.84 displays it as fully opaque.
Thanks for testing.
:arrow: Reproduced (Due to the remaining problem).
O.k., thank you, I can also reproduce the problem. Issue 1251 is fixed in next version.
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
xnview wrote:This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
Confirmed fixed :bugfixed:
