Dear user,
XnView 2.38 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
http://download.xnview.com/XnView-win.exe (English Setup, Multi language)
http://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
http://download.xnview.com/XnShellEx.exe
http://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
http://download.xnview.com/XnShellEx64.exe
http://download.xnview.com/XnShellEx64.zip
SHA256:
XnView-win.exe: 7F8076A3321DA19FFF454D3AD6508B4D163011D2BE81D208705CD6FA2EABC096
XnView-win-small.exe: 26CB81BC033A178C8075C23C5A3A55EF16BC98B4EEC49658D8A8947090AAA709
XnView-win-full.exe: C5BE5A94AC17DFE6C7740A628E30DFB9BA2E63CCDD7E5F974BB5FD0664BBFA4E
____ 2.38 Changelog
Sort by exif - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32387
Zooming instead file navigation - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33917
____ 2.37 Changelog
Better HiDPI support
Change timestamp and video
GPS direction - http://newsgroup.xnview.com/viewtopic.php?f=35&t=33587
Right click (make selection) and delete - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33700
NConvert: Multipage extract - http://newsgroup.xnview.com/viewtopic.php?f=57&t=33879
____ 2.36 Changelog
FLIF format added
SVG support via rsvg-convert.exe - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31748
Search similar & extension - http://newsgroup.xnview.com/viewtopic.php?f=56&t=32840
Multipage save doesn't use read settings
PCT crash - http://newsgroup.xnview.com/viewtopic.php?f=36&t=33025
NConvert: -t start step for number in output name
____ 2.35 Changelog
#THUMB_WIDTH_MAX# & #THUMB_HEIGHT_MAX# - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30652
JPEGXR
Backspace not working in fullscreen
LibPNG 1.6.20
ZIPPack Addon - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31563
____ 2.34 Changelog
Delete doesn't work on view mode
Charset in treeview - http://newsgroup.xnview.com/viewtopic.p ... 0&p=127128
Bevel settings - http://newsgroup.xnview.com/viewtopic.p ... 4&p=126724
Sharpen in Resize dialog - http://newsgroup.xnview.com/viewtopic.php?f=34&t=32008
PNG icc profile checking - http://newsgroup.xnview.com/viewtopic.php?f=36&p=127277
alpha channel not copied in clipboard from browser - http://newsgroup.xnview.com/viewtopic.php?f=36&t=32034
Colors & checksum in Overwrite dialog - http://newsgroup.xnview.com/viewtopic.p ... 6&p=127412
LibPNG 1.6.18
SqlLite 3.8.11.1
NConvert # in filename - http://newsgroup.xnview.com/viewtopic.p ... 2&p=127142
____ 2.33 Changelog
'Use extension' setting - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31619
LIBIMAGEQUANT on 256 colors image - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31567
Long filename - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31586
Clear out of bounds - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31604
Saving in Webp remove 1st pixel
Del during selection - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31760
On some jpeg, EXIF can't be rewritten
____ 2.32 Changelog
User plugin & check extension - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31403
Find similar don't find duplicates
Sharpen thumbnails - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31351
gs subfolder checked - http://newsgroup.xnview.com/viewtopic.p ... 2&p=124739
Customized data/time variables broken - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31367
Batch convert use estimated jpeg quality - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31398
____ 2.31 Changelog
Enlarge zoom quality
____ 2.30 Changelog
NConvert: -embedded_jpeg to extract embedded jpeg - http://newsgroup.xnview.com/viewtopic.p ... 7&p=124337
NConvert: Placeholder for EXIF date modified&date taken in output filename - http://newsgroup.xnview.com/viewtopic.php?f=57&t=29936
$EXIF:DateModified[date format] $EXIF:DateTaken[date format]
NConvert: Extension not forced lowercase - http://newsgroup.xnview.com/viewtopic.php?f=57&t=30294
NConvert: saturation from XnConvert
New addon for upload on ImageShack/Imgur - http://newsgroup.xnview.com/viewtopic.php?f=35&t=25014
Pdf issue - http://newsgroup.xnview.com/viewtopic.php?f=57&t=31292
Rename dialog move top/bottom - http://newsgroup.xnview.com/viewtopic.php?f=34&t=23924
Export dialog remember last folder - http://newsgroup.xnview.com/viewtopic.php?f=34&t=15352
Rotate EXIF orientation only process needed files - http://newsgroup.xnview.com/viewtopic.p ... 4&p=124316
BPG format read support - http://newsgroup.xnview.com/viewtopic.php?f=79&t=31040
File information overlay after reopen - http://newsgroup.xnview.com/viewtopic.php?f=36&t=28540
Placeholder use part of text - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30984
[x-], [x-y], [-y], [x]
Option>Settings>File list>Misc>Exif date used to sort
LockZoom & fullscreen - http://newsgroup.xnview.com/viewtopic.php?f=35&t=31140
GIF Loop Slideshow & Quick slideshow - http://newsgroup.xnview.com/viewtopic.php?f=35&t=29154, http://newsgroup.xnview.com/viewtopic.php?f=36&t=7880
LibQuant for colors reduction - http://newsgroup.xnview.com/viewtopic.php?f=34&t=31063
Filter by image & disabled extension - http://newsgroup.xnview.com/viewtopic.p ... 2&p=122226
Alpha channel & enlarge resize - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30682
Similar files: now you can add files as reference - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30601
Sharpen view - http://newsgroup.xnview.com/viewtopic.p ... 9&p=121277
Change timestamp - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30930
XnShellEx: resize - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31004
Video gallery only first file used - http://newsgroup.xnview.com/viewtopic.php?f=36&t=23036
Convert Font script - http://newsgroup.xnview.com/viewtopic.php?f=36&t=1332
Non image filename not shown in statusbar - http://newsgroup.xnview.com/viewtopic.php?f=36&t=31018
Similar dialog, use extension in filename - http://newsgroup.xnview.com/viewtopic.php?f=56&t=30908
Back key settting - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30746
PAM format added - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30741
Thumbnail sharpen value - http://newsgroup.xnview.com/viewtopic.php?f=34&t=13348
Autodeskew in toolbar - http://newsgroup.xnview.com/viewtopic.p ... 5&p=119267
Screen dpi on Win 7/8 - http://newsgroup.xnview.com/viewtopic.p ... 6&p=119294
Pause/Play animated gif - http://newsgroup.xnview.com/viewtopic.p ... 2&p=119543
Color picker and greyscale picture - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30215
"Rename all" in OVerwrite dialog - http://newsgroup.xnview.com/viewtopic.php?f=56&t=29151
DDS L8 format - http://newsgroup.xnview.com/viewtopic.php?f=36&t=25507
Settings saved after changes - http://newsgroup.xnview.com/viewtopic.php?f=34&t=30866
Clear in batch convert
Previous focused tab in IPTC dialog - http://newsgroup.xnview.com/viewtopic.php?f=35&t=27902
[IPTC]/PreviousTab
XnView 2.38
XnView 2.38
Re: XnView 2.38
Thanks for providing the new version 2.38, Pierre. Especially the bugfix of the mouse wheel was important.
- Moderator & Librarian
Re: XnView 2.38
VirusTotal scan results including file sizes and SHA-256 hashes:
- XnView-win-small.exe (3'611'624)
26cb81bc033a178c8075c23c5a3a55ef16bc98b4eec49658d8a8947090aaa709 - XnView-win-small.zip (4'457'875)
415a866d1e8dd6be6e088e133e6dafbebdfc82a9f11a2cded7ee267aac77631d
- XnView-win.exe = XnView-win-en.exe = XnView-win-fr.exe = XnView-win-de.exe (5'383'072)
7f8076a3321da19fff454d3ad6508b4d163011d2be81d208705cd6fa2eabc096 - XnView-win.zip (7'529'216)
23f9f9b8e117e7c5c6a3af67e97aa1ddb2e52839229a78ff06c27613a45d955f
- XnView-win-full.exe = XnView-win-full-fr.exe = XnView-win-full-de.exe (19'338'440)
c5be5a94ac17dfe6c7740a628e30dfb9ba2e63ccdd7e5f974bb5fd0664bbfa4e - XnView-win-full.zip (24'292'530)
7fea0563390728560d635dbbafb5b87df589ab46a758351e2c127fc26e3015bc
- XnShellEx.exe (1039'744)
b7539b712109b7ed790a455ac2c255cead1f7f08155ee19fb8a2a0c2e7d68861 - XnShellEx.zip (873'099)
ea68933457f985fdee5b91c5993002c839b22995ccc7b61f56305399f5eaf471 - XnShellEx64.exe (1'155'184)
845d9f13590ad058a056b2df57bd2ab9a7870594422b90f630d51c69c23376a2 - XnShellEx64.zip (1'047'364)
45c2ac66c5f60c27c727df1aa453298c38ba07ae5b3de400f5c81ef9f997a52b
Re: XnView 2.38
Thanks for the update!
Mousewheel is working again.
Re: XnView 2.38
And the rest of the bugs reported since 2.36 you are going to fix when?
Backdoor? https://www.virustotal.com/en/file/415a ... 477668207/
Before "false positive", it might be a false positive, but might be this particular antivirus knows something others don't.
Re: XnView 2.38
It's a false positiveuRsti11anError wrote: Backdoor? https://www.virustotal.com/en/file/415a ... 477668207/
