2.37: Mousewheel navigation: Zooming instead of navigating
captaincavern
Post by captaincavern »
Hi, with latest version (2.37) I have a problem with the mousewheel. It's set to navigate between images but very often it zooms in-out instead. It's so annoying I had to revert back to 2.36.
Re: Mousewheel navigation issue with 2.37
captaincavern wrote:Hi, with latest version (2.37) I have a problem with the mousewheel. It's set to navigate between images but very often it zooms in-out instead. It's so annoying I had to revert back to 2.36.
Confirmed...
Settings:
Tools > Options... > Keyboard/Mouse -- Mouse wheel set to Previous/Next file
Tools > Options... > View -- Misc tab -- Loop on the file list : seems to occur for either setting
Attached are some test images of numbers that might help establish when the issue occurs.
Test_images.zip
(12.61 KiB) Downloaded 224 times
Re: 2.37: Mousewheel navigation: Zooming instead of navigati
strange, that this bug doesn't occur with 2.36
d4rk0n3
Post by d4rk0n3 »
confirmed, downgrading it's killing me already!
PeterBo
Post by PeterBo »
bug confirmed here as well. Win 7 64bits
First I wondered my mouse is defect,
Then reverting back to 2.36: problem gone
PeterB
mbianco
Post by mbianco »
Same bug confirmed on my end.
Does anyone have the installation file for version 2.36? I cannot seem to find it anywhere, and 2.37 is just not working for me right now. Getting kind of desperate here!
Thank you in advance.
Update: Nevermind the above request! I found the installer for version 2.36 here: http://download.xnview.com/old_versions/
This bug in an often used feature of XnView. Pierre will release a fixed version, soon.
montu
Post by montu »
Confirm bug with WIindows 7 64bit.
Downgrade to 2.36 and waiting for fix.
uzip
Post by uzip »
Many thanks, Helmut and Pierre.
The better the program is, the more demanding we become, but it doesn't mean that we do not appreciate the superb job that you are doing.
Waiting for the fix.
A big thank you.
Uzi
Le_Sage
Post by Le_Sage »
En effet, je confirme le bug depuis la 2.37 la molette de la souris continue à faire le zoom au lieu du paramètre choisi dans les options, fichier précédent/suivant dans mon cas. Je voudrais juste rajouter que c'est aléatoire parfois il prend en compte le paramètre fichier suivant/précédent et parfois il zoom, sans raison, je n'arrive pas à reproduire le cas ou cela se produit systématiquement...
I confirm this random bug , and i'll wait for a fix.
namavic
Post by namavic »
Pour ma part, je constate que lorsqu'il y a plusieurs onglets d'ouverts, le zoom par la molette n'a pas d'effet sur l'onglet sélectionné, mais sur un autre onglet.
