0.78: 100% of core usage from time to time
Alt Bass
Post by Alt Bass »
It is quite stable overall but sometimes I get dead hang: 100% core usage while no files are accessed.
It occurs from time to time, I have no specific ways of reproducing it. There is nothing specific happening at the time of hang - I only guess that it happens after I assign a colour label and return to browser by hitting ESC or ENTER.
Windows 7 x64 SP1 0.78 x64 installable
Problem signature:
  Problem Event Name:	AppHangB1
  Application Name:	xnviewmp.exe
  Application Version:	0.77.0.0
  Application Timestamp:	569517cd
  Hang Signature:	8bdc
  Hang Type:	0
  OS Version:	6.1.7601.2.1.0.256.48
  Locale ID:	1049
  Additional Hang Signature 1:	8bdc13ee339e40ebfe9115602c74f506
  Additional Hang Signature 2:	2394
  Additional Hang Signature 3:	2394c4d251ec29af07a1565476ee9986
  Additional Hang Signature 4:	8bdc
  Additional Hang Signature 5:	8bdc13ee339e40ebfe9115602c74f506
  Additional Hang Signature 6:	2394
  Additional Hang Signature 7:	2394c4d251ec29af07a1565476ee9986
Here is a minidump (generated using ProcessExplorer):
xnviewmp.0.78.mini.zip
(334 KiB) Downloaded 56 times
Re: 0.78: 100% of core usage from time to time
it seems that the freeze comes from view mode and cache... Are you in view mode?
Alt Bass
Post by Alt Bass »
Freeze happened just after I switched to browse mode from view mode, right after drawing browse interface.
Thumbnail.db is 1.1GB.
jadO
Post by jadO »
I had reportetd high CPU usage previously as well: http://newsgroup.xnview.com/viewtopic.php?f=62&t=32171
Alt Bass wrote:Freeze happened just after I switched to browse mode from view mode, right after drawing browse interface.
in the folder do you have a lot of files? only images?
Alt Bass
Post by Alt Bass »
Few images (like 10 of them) and .pp3 files (RawTherapee profiles, like .xmp).
Alt Bass wrote:Few images (like 10 of them) and .pp3 files (RawTherapee profiles, like .xmp).
could you try to disable view cache?
Alt Bass
Post by Alt Bass »
What's that?
Anyway, even if I disable it, there won't be 100% guarantee that it is causing the issue because I cannot reproduce the bug repeatedly.
