SVG not rendering properly
Mixer
Banned
Post by Mixer »
XnTriq wrote:I still don't know why SVG(Z) is excluded by default, though :?
Maybe because the way XnViewMP renders SVG sucks? Try to open this file https://commons.wikimedia.org/wiki/File:Indus_IAU.svg with XnViewMP on default settings and with IE and compare outputs.
Moderator & Librarian
Re: SVG not rendering properly
Mixer wrote:Maybe because the way XnViewMP renders SVG sucks? Try to open this file https://commons.wikimedia.org/wiki/File:Indus_IAU.svg with XnViewMP on default settings and with IE and compare outputs.
There's “room for improvement” in Qt's SVG renderer and the CadSoftTools plug-in for XnView Classic which also has trouble displaying the semi-transparent/translucent objects.
Oddly enough, the result MP's Web capture command (Qt WebKit) produces of file:///X:/Test/Indus_IAU.svg seems to be perfect.
Mixer
Banned
Post by Mixer »
XnTriq wrote:Oddly enough, the result MP's Web capture command (Qt WebKit) produces of file:///X:/Test/Indus_IAU.svg seems to be perfect.
In case of my Win 10 x64 + XnViewMP 0.78 x64 command "Web capture" produces perfectly white blank image out of given .svg. With webpages and .jpg it works fine.
From left to right:
  1. XnView Classic: CadSoftTools plug-in = 24bit
  2. XnView MP: cmd_open = 32bit
  3. XnView MP: cmd_webCapture = 24bit
Click to view  full-res version!
Retested in v0.84: Not fixed
XnTriq wrote:Retested in v0.84: Not fixed
i'll contact Qt support
QT use SVG Tiny 1.2 format, symbol tags are not supported
