BPG 0.76 macosx
raysar
BPG 0.76 macosx
Post by raysar »
BPG decoding don't work on OSX, i don't know if it works only with a bpgdec.exe (i see it on plugin folder, but i didn't any bpg binary in xnviewmp.app) (xnviewmp on windows works great)
"le fichier ne peu être chargé!"
I have bpg install with brew, is there a solution to decode bpg on macosx?
I have some crash with wine.
Re: BPG 0.76 macosx
not added in MacOSX package. you need to add bpgdec in Plugins folder of xnview.app
raysar
Re: BPG 0.76 macosx
Post by raysar »
I added bpgdec binary in /Applications/XnViewMP.app/Contents/PlugIns and /Applications/XnViewMP.app/Contents/PlugIns/imageFormats
I also rename it in bpgdec.dylib ^^
What i must doing to make it works?
Re: BPG 0.76 macosx
ok, there is a bug, i'll fix it
raysar
Re: BPG 0.76 macosx
Post by raysar »
Thank you :)
