the moving files window pulldown menu
loth
Post by loth »
hello all,
in browser mode
pressing ALT+M to move or ALT+C to copy a file
the list of recent folders has 8 entries, but
using the cursor-keys to move between the entries
does not work correctly.
scrolling with the cursor-keys will result in showing only the two last entries
on my machine of course ;-)
so can anybody reproduce it?
also, i'd like to ask, how many entries the list is capable?
it would be a fine option if the pulldown-menu would remember about 50 entries, or even (configurable?) more, if possible.
loth
loth
folderlist doesnt update
Post by loth »
another appropriate issue:
if i choose an item of the last-folders-list, i would suppose, the folder-list would update to that new location.
(dunno, if this is a feature request, or a bug)
loth
Olivier_G
Post by Olivier_G »
I confirm:
You cannot browse with cursor keys in the list of recent folders, and are limited to swapping the first two.
About the 'recent lists': it would be nice to be able to select the max # of items (+unlimited) AND to delete the entries you want by pressing 'Delete' while hovering the entry in the list with the mouse.
Olivier
loth
Post by loth »
Olivier_G wrote:About the 'recent lists': it would be nice to be able to select the max # of items (+unlimited) AND to delete the entries you want by pressing 'Delete' while hovering the entry in the list with the mouse.
i support that too, of course. its a very important feature ;-)
loth
Re: folderlist doesnt update
loth wrote:another appropriate issue:
Ok, 2 problems...
loth
Post by loth »
Ok, 2 problems...
And the request from me, too. :-)
Please, could you add at least more than 10+- items as it counts now?
I often have to move hundreds of files to several directories.
It's kinda annoying that the list ist too short ;-/ and i cannot switch between my last 30+- directories.
loth
loth wrote: Please, could you add at least more than 10+- items as it counts now?
So 30 will be good?
Don't know if it's possible...
loth
Post by loth »
xnview wrote: So 30 will be good?
no :-) that was only an example. if you don't want to cache bilions of "old" directories, let the user choose.
in the options:
remember the last <NNN> directories.
hmm.. what makes it impossible?
loth
