ithmb support in NConvert and XNview broken
Henry_Jones
Post by Henry_Jones »
I've just noticed that the ithmb support in both Softwares are not working.
I had not used them ever before, but currently they only produce a scrambled Picture.
As some of the ithmb converters out there do not work either, I guess the format was changed meanwhile.
But as others do work, I suppose it should be possible to make them work again here also.
I'm right ?
Re: ithmb support in NConvert and XNview broken
please send me some samples
Henry_Jones
I've send you some samples on a freehoster and send you the link via PM.
Please inform me, when you have them so I can delete them there.
The highest Resolution in the files is a JPG which can be extracted with a hex Editor and is then a "complete" jpg file including the metadata. For the rest of the resolutions, I've no idea.
Depending on the i<Device> used the Maximum Resolution is different, I've seen files with about 4000 x 3000 Pixels in size.
The screenshots are from a software which can open this kind of ithmb files, just for your reference.
If there is something I can provide additonally, pleas let me know.
RandyDotCom
Post by RandyDotCom »
I have a fresh installation and the Convert function works even recusively through the xnView Gui. But the command line process creates grey Pixilated Blobs.
I think that the iPhone is changing formats underneath and the meta data is required for conversion.
