[SOLVED] No symbols in right click menu under Xubuntu
TD
Post by TD »
This is a screen shot from XnView MP running under Windows XP 32 bit :
And here a screen shot from XnView MP running under Xubuntu 14.04 64 bit:
Where have all the symbols gone ...
Regards,
Re: No symbols in right click menu under Xubuntu
i don't know, a setting of Xubuntu
TD
Post by TD »
Thank you Pierre for your answer that helped me to search myself.
First I have to add that the missing icons are not only the case for the right click menu but for all menus.
Well, I searched the net this evening and finally found out, that there is a bug in XFCE.
Fortunately it is easy to fix, I post it here for others who might stumble over the same problem.
In a terminal execute the two following commands:
gconftool-2 --type boolean --set /desktop/gnome/interface/buttons_have_icons true
gconftool-2 --type boolean --set /desktop/gnome/interface/menus_have_icons true
Open XnView and - voilà !
