2.22: Brightness menu not whole visible
surfacecleanerz
Post by surfacecleanerz »
when I try to open the Adjust Brightness\Contrast\Gamma\Balance menu in XnView 2.22 the menu is not usable. In the versions before everything was ok.
I cannot see the whole menu, just a small part. It is not possible, to zoom the window.
My System is Win 7 Ultimate 64 Bit.
Please fix this fast because so it is not usable any more...
Thank you for your great software!
Kind regards,
Stefan
Re: 2.22: Brightness menu not whole visible
In xnview.ini, please remove these lines
geometryH=
geometryW=
geometryX=
geometryY=
surfacecleanerz
thank you, that works!
kind regards,
Stefan
jocox
Post by jocox »
I have this problem with the Brightness menu not visible, but I am not sure where I find the xnview.ini? Thanks for your help.
Jo Cox
jocox wrote:I have this problem with the Brightness menu not visible, but I am not sure where I find the xnview.ini?
The currently selected xnview.ini file location is shown in the Info > About... window.
jocox
Post by jocox »
I found the location using your directions, but there are only two files in that folder and both are .db files.
