How to easily select photos by un-match orientation filter?
failed
Post by failed »
Dear sir,
I've over 10K of photos in multiple folders. I want to batch rotate those photos which the actual orientation of the photo is different from the orientation tag in EXIF.
I'm using XnConvert in Mac OS X. Do you have any suggestion on how can I easily select them out without eyeball checking the small icon appears in the "drag&drop" grid of the "Input" tap?
Cause I'm unable to define EXIF Orientation tag related filter criteria in the "Quick search" bar.
Jackie
Re: How to easily select photos by un-match orientation filt
there is no way currently :(
