0.64 win-x86: File not loaded on drag drop replace view
budz45
Post by budz45 »
please follow the below reproduction
1.) In XnViewMP's Settings>Interface , please enable "Single view for Multi-opened files"
2.) Make a new folder anywhere in Win Explorer
3.) Place any Three image files into this new folder (for example file01.jpg , file02.jpg , file03.jpg)
4.) Open the file01.jpg picture in XnViewMP view mode using double-click from Windows explorer
5.) Keep the same picture opened
6.) Now go back to same folder and Drag & drop all Three images to the same view mode while pressing CTRL key..
7.) ...A prompt error saying "File not loaded" is shown
NOTE: Remember that Drag & drop of file(s) to XnViewMP while pressing CTRL is normal behaviour meaning that while pressing CTRL the view mode tab simply gets replaced with new dropped item(s).
Re: 0.64 win-x86: File not loaded on drag drop replace view
See Issue 290 for current status and details.
budz45
Post by budz45 »
Thank you. Fixed in XnViewMP 0.68 :)
