problems with pdf files
madiazg
Post by madiazg »
I'm trying to open a pdf file but always returns me the Error 6 (unknown format). I use version 3.92 of libgfl. The code (in Delphi) is as follows:
gflGetDefaultLoadParams(mLoadOption);
mError := gflLoadBitmap(Pchar(FileNamePDF),mOriBitmap, mLoadOption, mInformation);
if mError =  GFL_NO_ERROR then
begin
  Label11.Caption := IntToStr(mInformation.NumberOfImages);
end else label11.Caption := 'Error: ' + inttostr(mError);
gflFreeBitmapData(mOriBitmap);
pdf file for example: https://mega.co.nz/#!cFczERbY!WQOF-krKw ... oPb8ACQL40
Can you tell me what is the problem?
Regards...
Miguel Angel
Re: problems with pdf files
do you have installed ghostscript?
madiazg
Post by madiazg »
I have not installed. Do I need to install it?
madiazg wrote:I have not installed. Do I need to install it?
yes
