JPEG Lossless Toolbar Button Problem
JohnFredC
Post by JohnFredC »
The options on the jpeg lossless rotation drop-down control displayable on the toolbars do nothing. In order to perform lossless jpeg rotation, I must click the button and select the rotation from the dialog that appears.
I have tested this on three different computers with versions 1.74 and 1.80. The only thing in common with between the systems is WinXP SP2.
John
marsh
Post by marsh »
For me (on Win2K), the jpg lossless keyboard shortcuts do not work (ctrl shift l & ctrl shift r). I cannot recreate button problem, perhaps XP users can.
---edit---
Lossless keyboard shortcuts work only in standard fullscreen.
---end edit---
Re: JPEG Lossless Toolbar Button Problem
JohnFredC wrote:The options on the jpeg lossless rotation drop-down control displayable on the toolbars do nothing. In order to perform lossless jpeg rotation, I must click the button and select the rotation from the dialog that appears.
Strange i have not this problem??
JohnFredC
Post by JohnFredC »
Just an update to this thread.
Same problem occurs in 1.80.1
I also notice that the Browser Tools-> JPEG Lossless Transformations menu options do not respond either. The "Dialog..." option does respond and all options work properly in the viewer.
To summarize:
Browser - Toolbar - Individual JPEG Transform options - NO RESPONSE
Browser - Toolbar - JPEG transform dialog - OK
Browser - Menu - Individual JPEG Transform options - NO RESPONSE
Browser - Menu - JPEG transform dialog - OK
Browser - Context Menu - Individual JPEG Transform options - NO RESPONSE
Browser - Context Menu - JPEG transform dialog - OK
Viewer - Toolbar - Individual JPEG Transform options - NO RESPONSE
Viewer - Toolbar - JPEG transform dialog - OK
Viewer - Menu - Individual JPEG Transform options - OK
Viewer - Menu - JPEG transform dialog - OK
John
ckit
Post by ckit »
I don't have any problems with JPEG Lossless transformations.
JohnFredC wrote:I also notice that the Browser Tools-> JPEG Lossless Transformations menu options do not respond either. The "Dialog..." option does respond and all options work properly in the viewer.
Very strange, i have no problem :-(
Someone has the same problem??
negg
Post by negg »
Not confirmed here (XnView 1.80.1, Windows XP SP2)
Martin
PLJ
Post by PLJ »
just tried with 1.80-1 works OK after install, but gives a popup dialog if i'm sure. But if I select the setting of not showing this dialog anymore the menu entries stops working and only the dailog box works.
Hope this helps because I have the problem on all PCs I use (win2000, XP home, XP prof)
JohnFredC
Post by JohnFredC »
What a great bit of sleuthing! I am positive I turned off the reminder dialog BEFORE I noticed the problem with the menus!
John
marsh
Post by marsh »
Does the problem go away when dialogues return? You can get these back by deleting a xnview.ini entry "ShowAgain=268435421" (back up xnview.ini before editing). Maybe this can help those who are having problem.
JohnFredC
Post by JohnFredC »
This entry is not in my INI file. I have two ShowAgains:
ShowAgain=2684354455
and then, further down
ShowAgain=-9
John
marsh
Post by marsh »
ShowAgain=-9
ShowAgain=268435421 is my entry which does display PDF warning.
ShowAgain=268435420 is my entry which does not display PDF warning.
So the numbers change depending on which questions you have answered yes/no to. Hope this is useful.
I only have 1 ShowAgain entry and have no problem.
PLJ wrote:just tried with 1.80-1 works OK after install, but gives a popup dialog if i'm sure. But if I select the setting of not showing this dialog anymore the menu entries stops working and only the dailog box works.
I can't reproduce it :-( Perhaps you can send me your .ini file...
JohnFredC
Post by JohnFredC »
Disabling either or both "ShowAgain" INI settings has no effect on the problem reported in this thread.
John
JohnFredC wrote:Disabling either or both "ShowAgain" INI settings has no effect on the problem reported in this thread.
Please send your .ini
Locked
