0.53: Improvements for File associations
budz45
Post by budz45 »
Since XnViewMP 0.50 (Windows) we have the resurrected ability to associate file-types to XnViewMP using it''s supplied 'Associate' tool.
There are some minor suggestions to functionality which I have noticed needs improving:
1.) After associating my file-types with XnViewMP, I used some file-type related tools such as File-managers which can analyze and display the file-extensions. I observed that some extensions need to be considered in a future version.
screenshots of my detection (click to enlarge):
Image Image
rle <-----in future must use same XnviewMP file ext icon as BMP
jfif <-----in future must use same XnviewMP file ext icon as JPG
jpe <-----in future must use same XnviewMP file ext icon as JPG
nef <-----in future must use same XnviewMP file ext icon as RAW
references:
http://www.xnview.com/en/formats.html
http://www.why-not.com/articles/formats.htm#BMPDIBRLE
2.) Small suggestion: The XnViewMP 0.53 association tool currently does not write "Type Name" to each file Extension in the registry. A quick use of the freeware tool, FileTypesMan, shows this to me.
for example;
For Bitmap (.BMP), XnViewMP currently just describes it as "BMP file (.bmp)" - When I think it could be better described as "XnView Bitmap (.bmp)"
from what I understand the Win Registry has two fields to be use which are 'type name' and 'type description'
two screenshots which show different associated file extension on my system giving a suitable 'description';
Clipboard 1.png (26.71 KiB) Viewed 1994 times
Clipboard 2.png (19.39 KiB) Viewed 1994 times
3.) Right, according to what FileTypesMan is telling me on my system, it seems that XnView 1.9x standard supports ICO association without changing file-type icon for .ICO . This is really impressive that XnView 1.9x does this and is the native way Win Explorer does it too.
Maybe what I did was to manually associate .ICO with XnView 1.9x using Win Explorer's "open with" <--'set default application' , which is what could have made Win Explorer assign no icon to it and leave it default because remember .ICO on Windows does not need file-type icon in association because it is an 'icon' itself.
I would like XnViewMP to do it this same way too.
4.) Question: Where is the 'ICNS' file extension written to in registry? XnViewMP has associated it on my system but I cannot find it in FileTypesMan...
sullysnet
Re: 0.53: Improvements for File associations
Post by sullysnet »
is the file associations set in MP like the old version or do you need to do them manually? I had an issue moving from old version to new
version before it was released. So I wanted to know if it is still an issue before spending time moving to MP.
thanks
budz45
Post by budz45 »
Use the tool like so:
I think that this tool was created to address certain limitation under Windows 7 file associating
sullysnet
Post by sullysnet »
thanks so much. I will try it out. I can also revert back since I've done it a few times I was just hoping to make the switch over and not go back.
GCRaistlin
Post by GCRaistlin »
Will Associate tool associate "more than 500 file types" that XnViewMP support? Now the list looks more than modest.
budz45
Post by budz45 »
GCRaistlin wrote:Will Associate tool associate "more than 500 file types" that XnViewMP support? Now the list looks more than modest.
Currently it only supports the most common-needed file types and the tool is not yet completed with the full absolute list
m.Th.
Post by m.Th. »
RAW files, brothers, RAW files... there is the business:
http://newsgroup.xnview.com/viewtopic.p ... 82#p112712
Also, I'd suggest, since Pierre is a graphics wizard, to generate the icons for the files.
m. Th.
