MacOS: Add HiDPI format/ Retina support
smartalan
Post by smartalan »
That is good software for preview picture under Mac.
But that is not support the HiDPI format, it's very blurred.
Could you help to support the HiDPI/retina version?
Re: Request : add HiDPI format/ Retina support
yes, currently QT framework doesn't support HiDPI... I wait for a fixed version...
.wojtek
Post by .wojtek »
*bump*? Is this still the case with QT? Would be nice to avoid all those blurry dialogs ;)
.wojtek wrote:*bump*? Is this still the case with QT? Would be nice to avoid all those blurry dialogs ;)
Do you have the same problem with XnConvert??
grgr
Post by grgr »
Is hidpi supposed to be supported by now? The images still aren't as sharp as with different viewers on retina.
grgr
Post by grgr »
Here is a screenshot with the mentioned difference.
Sorry if it's been already discussed elsewhere - I couldn't find any helpful results.
grgr wrote:Here is a screenshot with the mentioned difference.
i think that QT library has fixed this, so please check when next release will be available
andrelmsantos
Post by andrelmsantos »
Hi Pierre,
I've been using your softwares for several years and I can only say they're irreplaceable and incomparable. The highly customisable interface as well as the numerous features and ultra compatibility just make this app unique, beating any other out there such as ACDSee.
However, I've started using it in a MacBook Pro Retina for half a year now and the Retina compatibility has really become an issue when it comes to viewing images (especially photos). Do you have any ETA for the new Retina-enabled version with the QTlib update? I'd be even inclined to make a donation for the software development so as to recognise the efforts.
Thank you.
André
grgr
Post by grgr »
For me 0.76 doesn't fix the issue. Or do I overlook some setting?
grgr wrote:For me 0.76 doesn't fix the issue. Or do I overlook some setting?
could you post a screenshot?
grgr
Post by grgr »
It's quite the same difference.
andrelmsantos
Well, for me this version 0.76.1 solves the Retina issue. See the attached picture comparing XnViewMP 0.76.1 with Apple Preview at 100% zoom. It looks the same for me.
André
Comparison XnViewMP 0.76.1 x64 vs. Apple Preview at 100% zoom
grgr
Post by grgr »
It was always ok on 100%. The issue is specifically the look of downscaled images on retina.
andrelmsantos
grgr wrote:It was always ok on 100%. The issue is specifically the look of downscaled images on retina.
Right you are, grgr. When comparing XnViewMP and Apple Preview I can confirm the Retina incompatibility is still present ("fit to screen" zoom). Please refer to the attached image for more details (I highlighted the differences).
Comparison XnViewMP & Apple Preview
raysar
Post by raysar »
En mode retina sur macos (1280*800 sur un écran de 2560*1600) les icones(ce n'est pas un problème), les miniatures et les photos ne s'affichent pas en mode rétina.
Comme sur les screen précédents, on a 4 fois moins de pixel que prévu.
Le logiciel n'est probablement utilisé par personne sur des mac retina pour ça, il faut absolument passer en résolution native pour utiliser le logiciel.(en mode non retina)
J'avais compris que QT est assez galère à utiliser niveau retina c'était pour ça qu'on ne trouvait pas d'appli qt fonctionnelle sur écran retina, mais ça devrait quand même être faisable.
http://blog.qt.io/blog/2013/04/25/retin ... s-and-x11/
Est-ce que vous avez le temps de trouver une solution?
