IPTC - no results ...
Peter2
Post by Peter2 »
I tried to set IPTC to TIF. Here is my XBS:
  <?xml version="1.0" encoding="UTF-8" ?>
- <XnView_script version="1.0" name="all_iptc">
  <IPTC_XMP id_5="objektnm" id_7="statu" id_15="kat" id_22="jobid" id_40="sonst" id_65="progra" id_70="progv" id_80="fotog" id_85="titel des fo" id_90="stadt" id_92="locat" id_95="bundesl" id_101="staat" id_103="zeichen auftra" id_105="übers" id_110="bildre" id_115="quel" id_116="copyr" id_120="objekt" id_122="verf" id_100="coc" keepKeywords="true" replace="false" mode="0" />
- <Output folder="" filename="{Filename}_einz_#" case="0" format="TIFF">
  <Options overwrite="1" orgDate="true" keepMeta="false" keepICC="false" keepFolder="false" delOrg="false" multipage="false" allPages="true" openExplorer="false" clearItems="false" />
  <TIFF compress="2" quality="80" compressBW="6" oneStrip="false" />
  </Output>
  </XnView_script>
This is what I "exported to nconvert":
nconvert
The log-file of conversion says "OK", but there are no IPTC-data in my TIF.
What happened?
Peter
Re: IPTC - no results ...
works for me...
In Tiff/Settings, do you have disabled 'Keep IPTC'?
