Arithmetic decoding disabled in libjpeg-turbo
jgutierrez
Post by jgutierrez »
It seems that XnViewMP is not able to decoded JPEG files that use arithmetic encoding as opposite of Huffman. Since it is using libjpeg-turbo, it should be as easy as compiling with the define D_ARITH_CODING_SUPPORTED.
Is there any chance it would be added in future builds?
Thanks.
Re: Arithmetic decoding disabled in libjpeg-turbo
ok, do you have such jpeg?
jgutierrez
Sure!
Find attached some requested samples, nevertheless, you can always use jpegtran -aritmetic in order to convert a regular Huffman JPEG to Aritmetic, or jpegtran -optimize to do the oposite.
For your information, GIMP is able to view and edit arithmetic JPEG images with no problems too.
arithmetic_jpeg.zip
Arithmetic JPEG samples
(187.49 KiB) Downloaded 337 times
jgutierrez
Hello Pierre,
Were the samples I provided enought for you?
Do you want some more?
Thanks.
thanks, i'll check
dma_k
Post by dma_k »
I've just read two other related topics (Cant view lossless jpg and JPEG v9.1 now supports 12-bit color and lossless compression) and I wonder if JPEG arithmetic decoding is implemented in XnView Classic? As for XnView 2.35, it seems not to support arithmetic-encoded images.
Moderator & Librarian
dma_k wrote:[…] and I wonder if JPEG arithmetic decoding is implemented in XnView Classic? As for XnView 2.35, it seems not to support arithmetic-encoded images.
I just did a quick test with an arithmetic coded JPEG saved by Jpegcrop (2015.12 / IJG JPEG 9b). XnView MP v0.83 is able to open the file, but Classic v2.39 can't.
