LoadBitmap slow in vb webservice
branton1
Post by branton1 »
Hello
I recived this code from a collegue and it works fine when converting a pdf to a png in a simple visual studio form.
The problem is that I need to use the code on my webservice.
The problem is when I step through the code and execute the LoadBitmap(file) it just keep loading and no error comes up.
Here is the code I am using.
Dim g As New GflAx.GflAx
g.EpsHeight = 200
g.EpsDpi = 100
g.Page = 1
g.UseTransparency = True
g.LoadBitmap(fil.FullName)
g.SaveFormat = AX_SaveFormats.AX_PNG
g.SaveBitmap(pngfil.FullName)
I am currently using gflax version 2.82 with ghostscrip 8.64.
I am confident that their is no problem with my file as when I run the code on a simple form it works. (note: pdf is created using pdflib)
Is their any extra references that I need when using gflax with a webservice.
Any suggestions will help.
Thanks Liam
Re: LoadBitmap slow in vb webservice
gflax is registered?
