0.48 Win7 x64: Clipboard glitch (Essential!) and other bug
BK201
Post by BK201 »
0. Exiting the program will erase anything in the clipboard
1. Cannot remember the custom toolbar setting
2. File said it's edited when undo all the changes (still a * mark on the file name)
budz45
Re: MP 0.48 Win7 x64 Clipboard glitch (Essential!) and other
Post by budz45 »
BK201 wrote: 2. File said it's edited when undo all the changes (still a * mark on the file name)
Yes I have also myself discovered a similar or same bug regarding the ' * ' of unsaved view tab in which next/prev temporarily stops working...I am trying to make a reproduction for this bug
BK201 wrote:0. Exiting the program will erase anything in the clipboard
Currently a bug with Qt, i contact them...
I can't reproduce, you load your toolbar file, and not restored at next startup?
Ok, right
raina
Re: MP 0.83 Win10 x64 Clipboard wipe on exit
Post by raina »
Has anything happened with this? Just ran into the issue with current versions of XnViewMP and Windows.
JMM72
Post by JMM72 »
This doesn't happen with current 0.83 64bit under Win7. Actually the clipboard is untouched on exit since I started using XnView and switched to XnViewMP around 0.6x, so I guess you better give more indications about your version, environment, and how do you trigger the bug, and if it ever doesn't trigger.
raina
Post by raina »
JMM72 wrote:I guess you better give more indications about your version, environment, and how do you trigger the bug, and if it ever doesn't trigger.
Thanks for your reply, I'll gladly provide. I'm running MP 0.83 x64 on Windows 10 Pro x64. I've been unable to NOT trigger the bug, the clipboard is cleared reliably every time MP exits.
Steps to reproduce:
  1. Copy an image to clipboard.
  2. Pasting to other programs (IrfanView, GIMP) works.
  3. Start XnView MP.
  4. (Pasting to XnView MP and other programs still works. This step doesn't matter in terms of being able to reproduce the bug.)
  5. Exit XnView MP.
  6. Pasting to other programs (or a reopened XnView MP) no longer works.
raina wrote:Steps to reproduce:
  3. Start XnView MP.
  5. Exit XnView MP.
currently this problem is not resolved in QT API
xnview wrote:... currently this problem is not resolved in QT API
Thank you for the info, Pierre. The original poster and I consider this quite essential, so I put it on the list of Must fixes. Would be good if The Qt Company would provide a fixed version of Qt, soon.
BK201
Post by BK201 »
helmut wrote: Tue Feb 21, 2017 10:58 pm
May I ask if the Qt fixed his bug or not?
BK201 wrote: Sun Sep 23, 2018 4:58 am
always not :(
BK201
Re: 0.48 Win7 x64: Clipboard glitch (Essential!) and other bug
Post by BK201 »
6 years already, I think they added a WONTFIX tag to this issue.
I'll be glad if it was fixed before my funeral.
BK201
Post by BK201 »
7 years.
BK201 wrote: Sat May 11, 2019 3:22 am7 years.
QT has not fixed this bug :(
but i have added a workaround for windows
This problem is supposed to be fixed in XnView MP 0.94. Please check and confirm the bug fix here.
BK201
Post by BK201 »
xnview wrote: Tue Sep 17, 2019 10:24 am This problem is supposed to be fixed in XnView MP 0.94. Please check and confirm the bug fix here.
妈耶有生之年!
Soory i wos t∞ exiτed †o wαtch thïs, fiΠaΙly!
Thanks I will test it right away
