RC5: 'Purge most recent' needs renamed.
Locked
marsh
Post by marsh »
"Purge 'Most Recent Used Files & Directories' on exit"
>> Needs changed to>>
"Purge 'Most Recently Used Files & Directories' on exit"
(This is a much better English translation)
Button:
"Purge 'Most Recently Files & Directories' "
>>Needs changed to>>
"Purge 'Most Recently Used Files & Directories' "
Yes. Currently there is a mish-marsh with 'recent', 'recent used' and 'recently used'. Only the latter is correct.
Re: RC5: 'Purge most recent' needs renamed.
marsh wrote:"Purge 'Most Recent Used Files & Directories' on exit"
>> Needs changed to>>
Button:
>>Needs changed to>>
Ok
Dreamer
Post by Dreamer »
Changed in RC6.
Locked
