RC5: tip.ini with [uk] or [gb]?
Locked
Just a very minor issue:
In the new file 'tip.ini' containing the tips it currently says [uk] for English language. I wonder whether it should say [gb], instead. (Similar to the language code for the on-screen texts).
Re: RC5: tip.ini with [uk] or [gb]?
helmut wrote:Just a very minor issue:
Ok, right
ckit
Post by ckit »
This has been changed in RC6 - closed.
ckit wrote:This has been changed in RC6 - closed.
The [uk] has been changed to [gb] in the tip.ini, but XnView 1.80 RC6 does not support "[gb]".
-> Back to "New/Open".
In RC7 '[gb]' is used. Verified fixed.
Locked
