[Fixed]: sort of thumbnails after change of thumbnail labels
Locked
Anika
Post by Anika »
I look at the pictures in a folder in "thumbnails" view with several thumbnail labels. There are two subfolders and the files are sorted.
If I add a thumbnail label via the options the sorting gets confused in the first two lines. After refreshing with Ctrl+R everything is right again. This happens only if I add a label not if I delete one.
Before:
after:
XnView 2.04, 2.13 Windows 2000 SP4 and Windows XP SP3 and Windows 7 64bit
Re: RC5: sort of thumbnails after change of thumbnail labels
Anika wrote:I look at the pictures in a folder in "thumbnails" view with several thumbnail labels. There are two subfolders and the files are sorted.
Right, i fix it
Anika
Post by Anika »
Yes it it fixed. Thanks!
Anika
Locked
