RC5: High quality doesn't work in fs.lite sometimes
Dreamer
Post by Dreamer »
Just with some (probably large) images, strange...
Re: RC5: High quality doesn't work in fs.lite sometimes
Dreamer wrote:Just with some (probably large) images, strange...
Perhaps with the timer feature...
Dreamer
Post by Dreamer »
Sorry, I misunderstood.
Post by Guest »
I have found two inconsistencies regarding full screen and full screen lite:
-One of them (browser-> full screen) doesn't cycle images, the other one (normal view-> fullscreen) does, like I want it.
-One of them (browser-> full screen) uses a really cool feature: first the images are rendered low quality, but fast. After this the images are rendered high quality, which takes a little longer.
I wish the other fullscreen (normal view-> fullscreen) would use this behaviour, too! :)
Anonymous wrote:I have found two inconsistencies regarding full screen and full screen lite:
With Next/Previous?
Really, i remove it. take a look at this thread:
http://newsgroup.xnview.com/viewtopic.php?t=2307
Dreamer
Post by Dreamer »
xnview wrote:
Anonymous wrote:-One of them (browser-> full screen) uses a really cool feature: first the images are rendered low quality, but fast. After this the images are rendered high quality, which takes a little longer.
Pierre, please read my last post there...
Post by Guest »
With Next/Previous?
With the mouse wheel set to previous/next file (see options>view>keyboard/mouse)
This is a shame. I don't care for this feature in the preview screen, but in fullscreen it is really nice. I can cycle pics as fast as I can turn my mousewheel, but I can also view them in full quality after a short delay.
Please reconsider your decision or make it optional. Image It really makes a big difference when viewing .jpgs bigger than a few hundred kB, but even with small pics it is great Image
Anonymous wrote:Please reconsider your decision or make it optional. Image It really makes a big difference when viewing .jpgs bigger than a few hundred kB, but even with small pics it is great
I thought too ;-)
Post by Guest »
btw: I have the following machine:
AMD 1800+, 256MB RAM, GeForce4 MX, 80Gb HD, XP Home SP 2
I think on slower machines the difference is even more noticable.
Dreamer
Post by Dreamer »
I thought too ;-)
Again - Pierre, please read my last post here.
Dreamer
Post by Dreamer »
HQ still doesn't work...
- default settings (rename xnview.ini file)
- enable "Use delayed HQ..." option, value [0] (under Options>View>FS)
- enable "Fit image to window,large only" option (under Options>View>FS)
- download my jpg file (or/and try another 100+kb 1600x1200 jpg file)
- palce it in any filder with at least 5 images (no reason, just for switching)
- open it in FS lite (F11 in browser)
= HQ doesn't work
- switch to another image and back
= HQ doesn't work
- press numpad '*' and '/'
= HQ works
Strange - if "Use delayed HQ..." option is disabled, all "High zoom quality" options (reduce, enlarge, fit to...) are disabled - HQ for my jpg file works then (in FS lite) - another bug?
Dreamer
Dreamer wrote:HQ still doesn't work...
= HQ doesn't work
= HQ doesn't work
= HQ works
Ok, i understand perhaps the problem. Do you have Options/Browser/Preview/High quality, because i use it to make HQ :-(
Dreamer
Post by Dreamer »
xnview wrote:
Dreamer wrote:#1 HQ still doesn't work...
= HQ doesn't work
= HQ doesn't work
= HQ works
#2 Strange - if "Use delayed HQ..." option is disabled, all "High zoom quality" options (reduce, enlarge, fit to...) are disabled - HQ for my jpg file works then (in FS lite) - another bug?
Yes, enabled (it is enabled by default, see the 1st step above). That 2nd bug is not so important, important is 1st bug...
marsh
Post by marsh »
Confirmed problem.
With delayed HQ at 512 pixels (using F11 to go to fullscreen):
Delayed HQ does not work at 1600x1200.
Delayed HQ always works 758 x 972.
Problem can be seen by looking for the lack of flickering filename and by comparing quality of very large preview area & fullscreen.
marsh wrote:Confirmed problem.
Ok, i've found when fitted picture is exactly display screen...
Locked
