Filename descriptions mismatched
marsh
Post by marsh »
Filename's template menu have items which are not well matched. {Filename} is described as 'Filename without extension' instead of 'Filename' (which is being used for {Filename With Extension}).
Re: Filename descriptions mismatched
What' the problem???
You have {Filename} & {Filename With Extension}
marsh
Post by marsh »
Choosing "Filename" with insert button does not use "{Filename}" in template. Different than v.1.98's filename items.
oh right. But what is better as menu item. "Filename with extension" or "Filename without extension"?
marsh
Post by marsh »
'Filename with extension' since it resembles style which batch renamer uses.
marsh wrote:'Filename with extension' since it resembles style which batch renamer uses.
But by default, a filename is with extension :)
marsh
Post by marsh »
Labels 'Name and suffix' & 'Name' would dodge these points. :)
Vapavite
Post by Vapavite »
Ok, marais !
Vapavite @+
So what is the better :)
Filename with extension / Filename
Filename / Filename without extension
Filename & extension / Filename
Name & extension / Name
Moderator & Librarian
I'm glad you brought this issue up, marsh.
XnView v1.9
  • Tools » Options... » Browser » Browser » Show tooltips
    • Filename with extension ~ <Filename With Ext>
      Filename ~ <Filename>
    Tools » Options... » Browser » Thumbnails » Thumbnail Label
    • Filename
      Filename (without extension)
XnView^MP v0.35 beta
  • Tools » Settings... » Browser » Browser » Use tooltips
    • Filename ~ {Filename With Ext}
      Filename without extension ~ {Filename}
    Tools » Settings... » Browser » Thumbail » Labels
    • Filename
We need a unified nomenclature in XnView, XnView^MP, and XnConvert for...
  • Browser labels
  • Browser tooltips
  • Title bar info
  • Fullscreen info
  • Contact sheet info
  • Web page info
Vapavite
Post by Vapavite »
With filename extension / Filename
Present in the reverse order in the menus and other
Filename / Filename With Extension
Looking forward
Vapavite @+
