RC4: Dual Monitor Support buggy?
Locked
schulze
Post by schulze »
hi there
i tested the new dual monitor support but it doesn't work like expected (at least for me)
the "dual monitor, stretch over all monitors" options works
but the second option to view images fullscreen on my secondary display doesn't.
the text in the brackets is cutt off and it starts with "Brows..."
moving the browser on my secondary display, maximizing it there and trying to display an image fullscreen still results in display the pic fullscreen und my primary display. am i doing something wrong?
hope you can fix this one or tell me how to get it working
keep up the good work :)
Re: RC4: Dual Monitor Support buggy?
schulze wrote:but the second option to view images fullscreen on my secondary display doesn't.
Put Xnview with browser on primary monitor, select a thumbnail, popup menu and fullscreen. Is like that you have tried?
schulze
Post by schulze »
i just tried (browser on primary >> right click on thumb >> view in fullscreen) an the pic still pops up fullscreen on primary display :(
Dual monituar stretch is not enabled??
schulze
Post by schulze »
i just checked this with a friend of mine.
with his setup the feature is working whether he uses two monitors or one monitor + tv-out (like i do).
driver settings seems to be the same too
weird :|
edit: no streching enabled. didn't change anything since extracting the .zip
schulze
Post by schulze »
GEEEEEEEEEEE!
figured it out...
the secondary display NEEDS to be on the RIGHT side of your primary display (at windows display settings)
if you put it on the left side it won't work (at least with my setup)
hope this helps you
greetings schulze
Aokromes
Post by Aokromes »
It's strange for me strech works fine.
BTW this feature ownz me.
schulze
Post by schulze »
just installed the latest nvidia drivers (77.13) to see if they solve this issue but they don't.
so the problem persists:
secondary display on the right > everything's working fine
secondary display on the left > picture fullscreens on primary
strech is working correctly on both
Aokromes
Post by Aokromes »
Hi, this is how i have:
Nview display mode: Dual view.
Primary display: Monitor #1 conected via vga standard out
Secondary display: Monitor #2 conected via dvi with a dvi->vga adapter
Primary display on right, Secondary display on left.
And as you can see with my jpg is working.
schulze
Post by schulze »
ok...just checked rc5 and everything (strech and fullscreen display) is working fine for me now!
I'm replacing 1.74 with rc5
nice work pierre
thank you
Locked
