RC4: Thumbnails rotate out of correct perspective!
Locked
Andy
Post by Andy »
Just opened my picture folder in RC4 using Layout 3.
Many of the pictures are displaying with the thumbnails mistakenly rotated. Others are showing the drop shadow the size of the thumbnail's selected dimensions, not the image's bounding box.
Anyone care to verify this behavor? I can't tell what's to blame (perhaps a tools option somewhere).
Thanks,
Andy
Andy
Post by Andy »
I think I've figured this one out.
The files that I rotated a long time ago are the thumbnails that are rotated as if they were in their original orientation. They display in the Preview pane and Image window correctly.
I didn't know that images kept that kind of historical information!
Andy
Andy wrote:The files that I rotated a long time ago are the thumbnails that are rotated as if they were in their original orientation. They display in the Preview pane and Image window correctly.
The images have an EXIF orientation flag. XnView 1.80 auto-rotates the images automatically (by default). You can either deactivate the option "Rotate images based on EXIF orientation" or fix the images. For more details please see topic How to rotate images automatically?.
Also, there is the embedded thumbnail which might not have been rotated when rotating the image. See topics RC3: Option "Use Embedded Thumbnail" active and RC3: Icon for embedded thumbnail for some info.
Andy wrote:I think I've figured this one out.
You have in some jpeg a embedded thumbnail.
Andy
Post by Andy »
helmut wrote:The images have an EXIF orientation flag. XnView 1.80 auto-rotates the images automatically (by default). You can either deactivate the option "Rotate images based on EXIF orientation" or fix the images. For more details please see topic How to rotate images automatically?.
Thanks, Pierre!
That "Read" option wasn't default in earlier RC's.
All the best,
Andy
Locked
