RC4: Use Shadow in Options
Locked
m.s
Post by m.s »
I have check the 'Background/Thumbnail background' boxes in 'Options/Browser/Thumbnail' for old 3D-Look. If I want to check the 'Use shadow' box now, I didn´t get shadow under the thumbs. First I must uncheck these two boxes, then I get shadows under the thumbs.
Is this a bug?
Regards,
Micha
Re: RC4: Use Shadow in Options
msone wrote:I have check the 'Background/Thumbnail background' boxes in 'Options/Browser/Thumbnail' for old 3D-Look. If I want to check the 'Use shadow' box now, I didn´t get shadow under the thumbs. First I must uncheck these two boxes, then I get shadows under the thumbs.
Is this a bug?
Yes, you can't use the 2 options.
Danny
Post by Danny »
I can confirm this. If you keep the thumbnail background options activated and then activate the shadow it will keep the colored background. You have to unselect the background settings to make the shadow show back up.
Is this a bug?
If these options exclude each other they should be deactivated if "Use shadow" is active. And the other way round.
Still blurred
:) Hi !
- Here under Win 98 SE, the option "Shadow" for the thumb-nails is blurred still in RC4… ?
:mrgreen: KR,
helmut wrote:
Is this a bug?
Yes, right i fix it
Danny
Post by Danny »
xnview wrote:Yes, right i fix it
Fixed in RC5 using WinXP.
Dreamer
Post by Dreamer »
Clo, what about Win 98?
Post by Guest »
In windows 98 'Use shadow' is still disabled in RC5, but it don't bother me. (maybe theres no way to get it work right in win98)
ckv
Post by ckv »
Anonymous wrote:In windows 98 'Use shadow' is still disabled in RC5, but it don't bother me. (maybe theres no way to get it work right in win98)
:| me. (mini me)
“Not supported”
:arrow: Dreamer
:) Hello !
- In the French section, Pierre answered that the shadow (shade) is not supported under Win 98 SE for the thumbnails, no more … :|
- It's a bit amazing for me, since it worked in RC2 (rather ugly, though…)
:mrgreen: KR
Dreamer
Post by Dreamer »
OK, moved back to "New/Open" - let Pierre decide - to "Postponed" or "Closed/Solved" or "Fixed in RC6" :wink: ?
Dreamer wrote:OK, moved back to "New/Open" - let Pierre decide - to "Postponed" or "Closed/Solved" or "Fixed in RC6" :wink: ?
Yes solved
Locked
