Description on website
Currently the description used is:
"XnConvert is an easy image converter for graphic files, photos and images available on Windows, MacOSX and Linux.
It supports more than 400 file formats (jpeg, tiff, png, gif, camera raw, jpeg2000, WebP, OpenEXR, ...). You can resize, add a watermark, change contrast, brightness or gamma, apply filters and many other things."
If you have a better description, no problem :D
budz45
Re: Description on website
Post by budz45 »
Don't forget to include "batch image converter" and not just 'image converter'
..Other than that, the description so far is fine.
vaejiofr
Post by vaejiofr »
This is my own description. I think the word "dozens" accurately describes the number of options available.
XnConvert is a batch image converter and resizer that is powerful yet easy to use. All common picture and graphics formats are supported as well as over 400 other formats. Dozens of options are available, including resize, rotate and flip, add watermark, adjust color and brightness, and many more.
XnConvert is free software for Windows, Mac, and Linux. Both 32-bit and 64-bit builds are available.
Peter2
Post by Peter2 »
vaejiofr wrote:....XnConvert is a ....
Well done - sounds good.
Peter
budz45
Post by budz45 »
Here is mine below in purple :D
XnConvert is a cross-platform batch image-converter and resizer with a powerful and ease of use experience. All common image formats are supported (i.e. JPG,PNG,TIFF) as well as supporting over 400 other image formats. Also available within the batch operations include rotating, adding of watermarks, adding of text along with many image-adjustment features such as brightness, shadows and more.
XnConvert is free software for Windows, Mac, and Linux. Both 32-bit and 64-bit editions are available.
Among the features included are:
• Batch adding of files and folders
• Support for drag-n-drop of files
• Batch rotating, cropping, resizing and more
• Scripting support
• Adding of photo masks
• Preserving or removing image metadata in conversions
• Multipage image file support (i.e animated GIF, APNG)
• Command line integration via NConvert
• Filters - such as 'Blur', 'Gaussian Blur', 'Emboss', and much more
More interesting and critical features are to arrive soon...
budz45
Post by budz45 »
Hi again Pierre and forum members,
Thank you for selecting my written description, it's an honour to see it on the XnConvert website. :D I just thought I would share what was on my mind, so far, with regards to minor clean-ups that could be done on the current written description.
Small apologies, it's actually written as Drag-and-drop : http://en.wikipedia.org/wiki/Drag-and-drop
http://xnconvert.com/description
• Effects - such as 'Old photo'
At the end of this sentence add the suffix 'and much more' so that it reads; Effects - such as 'Old photo' and much more. Hmm in XnConvert v1.02 where is this 'Old Photo' under actions tab? I'm trying to find it.
• Language supported:
Language supported:
More critical and interesting features are to arrive in future...
budz45
Post by budz45 »
Pierre,
Where is this "Old photo" feature in XnConVert? I'm trying to find it :?
I think it was in older version before v1.02, no??
budz45 wrote: Where is this "Old photo" feature in XnConVert? I'm trying to find it :?
Misc>Old camera
budz45
Post by budz45 »
Oh ok. So in which case this part of the description:
• Effects - such as 'Old photo and much more
Should be changed to this:
• Effects - such as 'Old camera', 'Mosaic' and much more
Second thing is, you need to put the version number in large text in the downloads section (xnconvert.com/downloads) - a user reported this by 'shout' on the xnconvert website.
budz45
Post by budz45 »
Why is there no update for the French or German written Description on the website?
budz45 wrote:Why is there no update for the French or German written Description on the website?
yes need to be translated :)
marsh
Post by marsh »
Borders - squared, rounded, or multiple
Peter2
Post by Peter2 »
marsh wrote:Borders - squared, rounded, or multiple
Peter
marsh
Post by marsh »
Misc>border. It makes borders now. Recalling advice to expand canvas seen in old program.
budz45
Post by budz45 »
Also you need to update the RSS of the French and German website versions..It's still got old RSS update. Please make sure the RSS is completely automatic. :|
